poison1
White Laminate Flooring
I am thinking of putting white laminate in my sitting and dining room.
has anyone done it currently and is the gap between the laminate very obvious as it is on a white background?
TIA
TIA
i can foresee the dirt trapped along the joints will be fairly obvious..... :unsure:
i plan to use silver pine laminate which looks silvery white :) the gaps won't be obvious as it's not pure white.
On budget? Why not use vinyl sheets? Gap between 2 pieces of laminate should be about 0.8mm.
Robina have white Laminate flooring, looks great! Its come with soft wood grains...
try tarkett as well. they have good white especially frm the TLF 009 Seagrass Zen. im going to use the white for the living dining and the seagrass spirit for the rooms.
Yeah ordered that. Coming to fix this Fri. :P
Cool! You got it from Floor Option right? Saw your other post...
Their workmanship is very good too...! Worth it! Show us your floor once you have install!
Cheers!
Guest Goobii
U will foresee to see trap dirt at the joint area ....
I wanted white laminate too but after much research and even visited those shopping mall and friends house. I chosen Gray Laminating instead, as the dirt is less visible and also the colour is unique..
Cheers!
Yes yes posted in another thread. Go check it out!
