jsaputra
Professional Engineer Contact
Hi all,
Could you guys share contact info on good and reasonable professional engineer (PE) for approving some renovation work?
Thank you in advance.
Regards,
jsaputra
Hi all,
Regards,
jsaputra
just curious, but do you really need a PE to approve reno work? cos i thot an LEW (licensed electrical worker) would do.
or u mean a Civil PE?
regards,
joe
regards,
joe
Hi Joe,
That's right, it's Civil PE I need. Planning to do some wall hacking and would like to get a few PE to check their rate and engage the most reasonable one. I think it's good to have options and do my own checks before deciding.
Do know any you could recommend? Mind sharing the contact? Thank you!
Regards,
jsaputra
Hi Joe,
Regards,
jsaputra
Sorry, i won't be of much help cos i dun hv contacts for Civil PEs, only Electrical ones.
cheers,
Joe
Hi Joe,
Regards,
jsaputra
jsaputra,
have you found a reliable Civil PE ? pls share cotacts with me.
jsaputra,
What kind of hacking will be done? The PE will also need your licensed contractor to carry out the work, PE and licensed contractor are together..
i am doing a lot of hacking to reposition my granny's room, kitchen,first floor toilets and create a new maid room. i am also thinking of converting my non acess roof to balconies for upper floors. i need PE to determine if wall can hack and the load the roof can take... let me know if PE is not necessary
Private property? It will be good to check if there is any structural that cannot be hack or to the extend of how much can be hack.
