Can Us Applicance Be Used In Singapore?
Get a higher Ample rating to cater for the heavy load if needed
Get a higher ample rating to cater for heavy load if needed
Try to avoid TVs...its more than the voltage difference...
must get a step up transformer.
Check the voltage and current.
correct me if I'm wrong, but I think it's step-down transformer (Our voltage is 230V to be step downed to 110v to suit the US appliance).
Try to get a transformer that can take at least 25% more than that required by your appliance
ya. U are right.
I make a mistake.
Just check with my HW engineer. Should be step down
:P
he say to be ensure, make sure label says: 110V to 240V
Thanks for correct me :D
look at the label on the equipment. if it says 110-240. then no need for transformer. if its 110V only. then u need a transformer. and u need to know the current rating of the equipment. if its say 3A. try to get a 5A transformer at least. if no current rating. see the power rating. transformers come with power rating also
