April 19, 201214 yr My gas heater will be install nxt monday finally settle the case as afraid gas & water piping running like MRT system But after site survey by city gas tech he told me how the run & how to tap the cold water and run only the hot water pt to the heater.Was a relieved after hearing & straight went to sign up for Rinnai Will post pics later after install to shared with u guys You are taking up Rinnai heater? The CS was recommending Prima MA-10FE.Any particular reason?
April 26, 201214 yr My I'd mentioned that he will do the arrangement with city gas, or I am supposed to?
May 9, 201214 yr My ID placed order n will liaise with them regarding the date of installation. Think b fine.
June 27, 201214 yr any mo efeedback from it ... feel like getting it also ...So far so goodU want cold it comes out cold U want it hot it comes out hot Its not really that slow that u have to wait for hot waterMine is Rinnai u may check my T blog as I have installed
June 27, 201214 yr Can I check is anybody staying above 10 floor and using city gas water heater ? How is the water pressure ?
June 28, 201214 yr Can I check is anybody staying above 10 floor and using city gas water heater ? How is the water pressure ?I satying 14floor out of 20storey No complaint so far
June 28, 201214 yr I satying 14floor out of 20storey No complaint so far Thanks for your comment, Casa !Asking this question because currently I am staying at 4th floor, and moving to 15th floor (total 17 floor) by end Sept. Quite worry about the water pressure as I heard a lot of people complaining of low water pressure at high floor. Currently using gas heater, but not sure should I get gas heater, instant or storage heater when I moved over to my new place. Did you experience the inconsistency of the hot water ?
June 28, 201214 yr Thanks for your comment, Casa !Asking this question because currently I am staying at 4th floor, and moving to 15th floor (total 17 floor) by end Sept. Quite worry about the water pressure as I heard a lot of people complaining of low water pressure at high floor. Currently using gas heater, but not sure should I get gas heater, instant or storage heater when I moved over to my new place. Did you experience the inconsistency of the hot water ?No problem and worry on that heater bro.Lower floor will be supply by a pump to pump the water up to certain level as for top floor water tank situated up above will suppy to certain level below.No worry on water pressure bro I have seen people staying 40-35 installing gas heater Edited June 29, 201214 yr by casa
June 28, 201214 yr No problem and worry on that heater bro.Lower floor will be supply by a pump to pump the water up to certain level as for top floor water situated up above will suppy to certain level below.No worry on water pressure bro I have seen people staying 40-35 installing gas heater Thank you so much !
July 19, 201214 yr Hi..the sales staff at citygas told me that Rinnai heater got to install a 'flute' for ventilation/safety purpose if we were to have windows installed at service yard. But we are not going to close the windows all the time at service yard, so, we really have to cut a hole for the flute 24/7 ventilation?? It's not cheap too...Any one has experience on that?Thanks!
July 20, 201214 yr Hi..the sales staff at citygas told me that Rinnai heater got to install a 'flute' for ventilation/safety purpose if we were to have windows installed at service yard. But we are not going to close the windows all the time at service yard, so, we really have to cut a hole for the flute 24/7 ventilation?? It's not cheap too...Any one has experience on that?Thanks!I install Rinnai so far till today no issue my svc yard window is open I know there's a piping attached to the flue which cost $$$ which I think waste $$$
July 21, 201214 yr thanks casa...!That what i felt too, we are not going to close windows all the time, so there will be ventilation loh...Cos they told me once you got windows, whether you keep it open or close, they die die want you to install the piping.
July 21, 201214 yr thanks casa...!That what i felt too, we are not going to close windows all the time, so there will be ventilation loh...Cos they told me once you got windows, whether you keep it open or close, they die die want you to install the piping.Don't bother about them its just another tactic by them to make u buy Anyway if u worry Y not choose Ferroli its also good pricing same as Rinnai
April 12, 201313 yr anyone have lobang for good and reliable plumber to install water pipes to the city gas water heaters?
