The Sides Of The Drawers
Hi, the sides of the exposed drawers are now all plain ABS trimmings. However, i find that it doesnt match the laminate that I have choosen. Cant the sides be laminate? I thought ABS trimming is just to join 2 angled pcs of laminate? Just like the white gap between the tiles.
hi,
Sides/edges of the drawer's panel can be apply laminate, just that laminate is easy to crack and those normal laminate have "dark" lines on the edges. ABS is like made with PVC, plastic type material, hence will not crack.
during the time when you choose the laminate material, they shld have indicate whether does it come with the abs trimming. if yes, the color will be very near to it..if no most likely is what you are encountering...that what i understand. hopefully i'm right about it
