Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Hi Zero,
Am looking for a chimney hood (island hood) + stainless steel 3 hob? Any recommendation for someone who seldom cooks? Preferably something less than $900 for both.
Hi Eevee,
ok. pmed you.
Thanks.
Regards,
Jerome
  • Replies 2.3k
  • Views 765.7k
  • borntoslack
    borntoslack
    Hi Zero is the Rinnai offer still available, I'm getting my keys next week, afraid that the current "hole" that the hob is too small for Rinnai. Can PM me the special offer and specs if possible? than
  • Hi Zero, I am not too sure if i have posted at the right places as I am pretty new to this. Can i get the proce for turbo 753vtsc and hood t601-90ss Is the Rinnai RB2CG still available? How much and d
  • LG Washer Cum Dryer Model : WD1486ADP3 Price : $8XX Features6 MOTION INVERTER DIRECT DRIVE SYSTEM A+++ ENERGY EFFICIENCY BABY CARE Just Like Hand Wash When doing laundry, you might have experienced
Posted Images
Hi, do u carry built-in microwave? Can u quote me for Electrolux EMS26415X? Thx
Hi, can I have the quote for the appliance below?
1)Samsung LED tv-UA46D7000LM 46" 7 series.
2)Samsung top freezer fridge-RT72KASE.
3)Samsung washing machine-WD8804CJA.
4)Joven storage tank-JH25.
TIA
Some Sharing Regarding Rinnai RB2CG
Rinnai gas cooktop (see PIC 1) incorporates recessed, inner-flame burners into a Schott Ceran glass-ceramic panel to create an appliance that provides high-performance cooking capabilities with convenience and an easy-to-clean surface. A vortex of flame (See PIC 2) is created by angling the burner ports on the horizontal plane. The swirling flame aids combustion by helping to draw air. The unique flame also assists in distributing heat evenly across the bottom of the pan.
Inner-flame burner improves heat transfer efficiency.
Cutaway view of Rinnai’s inner-flame burner shows how the individual flames coalesce and rise toward the center. When the cone of flame hits the bottom of a pan, it flows outward across the bottom to ensure even heat distribution and efficient heat transfer.
o o o
Appliance-maker Rinnai Corp., Nagoya, Japan, has turned burner design completely around with its inner-flame burner. Instead of shooting flames outward from the burner perimeter, as with a conventional burner, Rinnai’s inner-flame burner is ported so that flames shoot inward toward the center.
The purpose of the unusual design is to create a coherent, unified flame that rises under the center of a pan, then flows outward, bathing the entire bottom of the pan in flame. This approach heats the pan with greater uniformity and improves the efficiency of heat transfer from the flame to pan.
In addition to aiming the ports inward, two other design factors assist in shaping the flame. One is that the burner sits slightly below the surface of the cooktop, helping the individual flames to coalesce toward the center as they rise through a hole in the cooktop surface. Secondly, and more importantly, the burner ports are angled slightly on the horizontal plane. (See top view in lower photo.)
The effect of the flames shooting out an angle is to create a fiery vortex. The swirling flame is meant to accomplish two things. One, it assists in driving the flame outward across the bottom of the pan, helping to evenly bathe the pan bottom with flame. Two, the vortex creates a pressure drop that assists in drawing air in for combustion.
The large version of the inner-flame burner has 24 ports and delivers a maximum output of 15,872 BTUs/hr. The burners are lit by direct-spark ignition.
Rinnai originally intended the inner-flame burner to be installed into a metal panel cooktop. Instead, Rinnai began working with Schott Corp. to find a way to implement the novel burner into a Ceran surface panel.
Schott’s technical support staff worked closely with Rinnai to address a number of issues. One of the biggest was concern over how to protect the burner and other
components from spills going down the hole. Another big concern was protecting the Ceran from direct exposure to excessive heat. Schott’s engineers devised a special burner sleeve to solve these potential problems. Schott also assisted with the design of the cooktop’s framing and a ventilation grid in the cooktop which serves two purposes: one, to provide primary air supply for the burners and, two, to vent exhaust from a fish griller beneath the cooktop.
Rinnai incorporated many of Schott’s design ideas in the final production model of the appliance.
The result was a unique appliance that successfully combines a novel, high-performance burner design and a convenient, easy-to-clean cooktop surface.
Schott says that the popularity of Ceran is growing in the Japanese market because the material’s cleanability is a big advantage in a region where cooking methods involve a lot of frying.
Rinnai says the cooktop with the inner-flame burners has been adopted by many Japanese cooking schools because the burner system is amenable to cooking different regional styles of meals, including Japanese, Chinese and French.
PIC 1
Uploaded with ImageShack.us
PIC 2
Edited by zero
Back to Popular Demand!!
Rinnai RB2CG
CALL / SMS me now to confirm your orders!
SPECIAL PRICE FOR ALL CONFIRMED SET!!!
LIMITED PERIOD ONLY!
Edited by zero
Hi
May i know how old is this model?
It has been in the market for a fairly long period. Rinnai is the only one in market with Inner Flame.
Can you pm the best price for the following item
1. Fujioh hood FX900
2. Turbo 703vtsc Triple burner glass hob
3. Fujioh oven
LED TV Price:
Philips
46PFL6606 - $1720
46PFL8605 - $1640
Sharp
LC46LE830M - $2290
Sony
46EX520 - $1880
42EX410 - $950
LG
47LW6500 - $2380
Hi Zero,
I am looking for Hood , hob and also oven, we will cook everyday furthermore is open kitchen concept, so need high suction of hood. i like baking, so hope to get a good oven. Any recommendation?
Do you have a shop where we can go down to see the model?
thank you
Can PM me the special offer and specs if possible? thanks in advance.
Hi Zero,
Is the promo for the Rinnai inner burner still on?
Can PM me the quote. Thanks~
Regards
Starice
Hi Zero,
Is the promo for Rinnai inner burner still on?
Can PM me the pricing?
Thanks~
Hi Zero,
Thanks~
Ok. Pmed you. Thanks
