Hob & Hood, Oven, Heater, Fridge, Washing Machine, Etc - Trusted Supplier Since 2011
Hihi, need your recommendations for my washing machine. My SS one died in about 6 yrs so need one urgently. Currently using a front load but am open to top load cos cheaper. Understand that front load saves water but not electricity cos wash cycle longer but top load uses more water but less electricity & clothings get spoil easily cos of the spin dry function. Need to wash king size beddings so looking at 8 or 9kg washer. Can let me know the cycle time for a normal wash?
  • Replies 2.3k
  • Views 765.7k
  • borntoslack
    borntoslack
    Hi Zero is the Rinnai offer still available, I'm getting my keys next week, afraid that the current "hole" that the hob is too small for Rinnai. Can PM me the special offer and specs if possible? than
  • Hi Zero, I am not too sure if i have posted at the right places as I am pretty new to this. Can i get the proce for turbo 753vtsc and hood t601-90ss Is the Rinnai RB2CG still available? How much and d
  • LG Washer Cum Dryer Model : WD1486ADP3 Price : $8XX Features6 MOTION INVERTER DIRECT DRIVE SYSTEM A+++ ENERGY EFFICIENCY BABY CARE Just Like Hand Wash When doing laundry, you might have experienced
Posted Images
707 Compact Heater !
Prefer Something Fuss-Free Without Compromising On Quality? The 707 Compact Shower Heater Is Just Right For You. Its Energy-And-Water-Saving Features Help Reduce The Utilities Bill While Its Stabilizer Valve Help Manage Water Pressure Fluctuations.
- Anti-Scald Device
- Pressure Relief Device
- Stabilizer Valve Control
- Power Selector Control
- Min Pressure 2.5 Psi
- Recommended Pressure 14.5 Psi
- Power Rating: 230V, 50/60Hz
Price : $188 * With $18 CASH ANG POW !
Promotion ends 20FEB 13, Or while stock last!
Thanks
Regards,
Jerome
92256638
homeappliances@hotmail.sg
Samsung 8Kg Washer
Model : WF1804
Feature
•Fuzzy Logic Control
•130 minutes
•15 minutes
•Vistula
•Jog Dial
•White Body Colour
•Chrome Door Colour
•Wide Graphic LED + Centre Time Display
•Spining Performance: A
•Spin Speed (Max): 1,400rpm
•Door Lock Display
•- INFORMATIVE FUNCTIONS > Child Lock
Display : [Yes]- Safety > Child Lock : [Yes]
•Time Left Display
•Progress Indicator
•- INFORMATIVE FUNCTIONS > Delay End up to 19 hours : [Yes]
- PROGRAMS > Option > Delay End : [Yes]
•Fault Check Display
•Rinse + Spin
•Pre-Wash
•Denim
•Silk & Lace
•Outdoor Care
•Baby Care
•OverVolt Control
•Cold fill only
•Dark Garment
•Daily Wash
•Heavy Wash
•Super Eco Wash
•Eco Drum Clean
•Rinse Time +
•Cold / 30°C / 40°C / 60°C / 95°C
•Anti-Foam Control
•Overheating Control
•Self Cleaning Filter
•Self Diagnostic System
•Eco Bubble™ Technology
•Sound Off
•Time Saving
•Easy Iron
•Intensive
•Ceramic Heater
•Diamond Drum
•Wrinkle Prevent
Price : $668 * with $38 CASH ANG POW !
Thank you.
Regards,
Jerome
92256638
LG Direct Drive Motor, 10years Warranty.
7Kg Washer
Model : WD1070
7kg White Direct Drive Washer
KEY FEATURES
•WD-1070 (W)600 X (D)550 X (H)850mm
•Capacity : 7 Kg
•Spin Speed : Spin Speed:1000rpm
•Others : Direct Motor System
•Dimensions : W600 X D550 X H850mm
•Others : Embossed Drum
Unique load sensor, auto setting optimum washing conditions, time and energy saving. You can complete your washing even when you are not at home with our preset washing time. A total cleaning satisfaction with our caring functions - Self-diagnose, Crease Care, Quick 30, Child Lock, Standby Power Zero etc.
Wool Care
With this specially designed wash cycle approved by Wool Mark, you can now clean your woolen clothing with care, minimising both damage and shrinkage.
Medic Rinse
This feature, only unique to LG Front Load Washers, helps to remove traces of detergent from your clothing by using a warm water rinse, especially useful for those with sensitive skin.
Direct Drive™System
The LG Inverter Direct DriveTM motor, now used on all our front load models, gives you a quieter and more durable machine. We attach the motor directly to the washing drum for more durability, less vibration, and higher energy efficiency. With lesser parts, you get less trouble and a longer warranty.
Standby Power Zero
Cut down of wasteful energy consumption with our Standby Power Zero feature. Even without switching off your main switch, this feature ensures that no electricity is supplied to your machine once it is powered off.
Baby Care
Given your baby’s sensitive skin the protection they need with our delicate baby care washing mode. By washing at 95°C and using warm water rinse (medic rinse) at the last rinsing cycle, this function will gently but thoroughly eliminate bacteria, germs and detergent from your baby’s clothing with utmost care.
Price : $588 * With $38 CASH ANG POW!
Thanks
Regards,
Jerome
92256638
Homeappliances@hotmail.sg
SMS / Whatsapp / Email for fast response.
Regards,
Jerome
92256638
Edited by zero
DARE TO COMPARE!
LOWEST PRICE IN SINGAPORE !
HOB AND HOOD JAPAN DEALS!
Rinnai Hob
RB2CG *Made in JAPAN
Fujioh Hood
FX900 *Parts from JAPAN
PROMOTION ENDS : 20Feb13, Or while stocks last!
PWP Happy call pan @ $18.00
Thank you.
Regards,
Jerome
92256638
Edited by zero
yo Zero,
Please provide prices for the following items:
RB-712N (G)
RB-713N (G)
Fujioh Hood FX900
Are you able to bundle them up and give special discount?
Cheers
Hi
Need quote on following items. You can reply me via ongzann@gmail.com
Bosch kan-62V00
Miele W1945
Miele T7944 C
Thanks!
Can you kindly provide quotes for the following:
- LG 55LM6410
- LG WFT9561DD
- Alpha Smart 18i
Also, appreciate if you can recommend ceiling fans, 52" or more, with and without lights.
Thank you.
Hi Zero,
Can you give me a quote for:
1) Rinnai RH991CT
2) Rinnai RB2CG
Thanks!
Has anyone bought/used hobs from Glem? Is it good? Mind sharing a review please?
hi zero,
I'm looking for Hood n hob to replace the existing one. cutout dimensions as below. pls recommend two model each.
1. hob - 82L x 48W cm (3 burners, prefer glass top, cast iron pan support)
2. hood - 90L x 15H cm (non chimney type)
pls include the installation as well. thx
Hi All,
Gong Xi Fa Cai.
Thank you for all who supported our CNY Offer.
All pm cleared.
Pls email/ sms for faster response.
Thanks
Regards,
Jerome
92256638
homeappliances@hotmal.sg
