Aircon Drain Pipe Into Service Balcony Instead Of Mbr?
Did anyone divert the Aircon water drain pipe into service balcony instead of MBR?
My installer insists to lay the drain pipe into MBR.
Usually water discharge pipe is to master room or common toilet.
Aircon drain pipe shorter distance is the best.
Very common for chokage to occur.
The drain pipe need to be able to vacuum out the slime inside during maintenance.
