4A Mainly Toilet And Kitchen
Hi All,
I am looking to renovate my 4A resale flat, some where in January 2013, need to start on the first week and complete it by the 21st of Jan 2013.
Also running on a budget, I am hoping for good quality and workmanship. The following are the details of the work that need to be done.
I hope any of you experienced reno forumers or contractors can give me a rough amount on the works below. Many thanks and much appreciated.
Dismantling Works
Dismantle existing sanitary @ master bathroom 1 set
Dismantle existing sanitary @ common bathroom 1 set
Dismantle existing kitchen cabinet
Dismantle ceiling fan in master bedroom and install light.
Masonary works
Overlay floor and Wall Tiles with waterproofing @ master bathroom 3000mm by 1700mm
Overlay floor and Wall Tiles with waterproofing @ common bathroom 2500mm by 1700mm
Supply & construct shower kerb @ master bathroom with matching tiles
Supply & construct shower kerb @ common bathroom with matching tiles
Supply labour to uplift sand, cement & materials to unit ( Haulage Loading )
Door Works
Supply & install nyatoh main door c/w lock set & magnetic stopper ( fire rated ) 1No
Supply & install flat nyatoh veneer doors c/w lever lock set & magnetic stopper 3No
Plumbing Works
Change both bathrooms cold water piping to new stainless steel pipe
Connect inlet & outlet piping for wash basin
Connect inlet & outlet piping for kitchen sink
Supply labour to install basin & pedestal WC @ master bathroom
Supply labour to install accessories @ master bathroom
Supply labour to install basin & pedestal WC @ common bathroom
Supply labour to install accessories @ common bathroom
Supply labour to install instant heaters
Supply labour to install kitchen sink, hob & hood
Miscellaneous
Supply & lay protection sheet
Clean up whole unit with chemical washing
Clearing off debris
Whole House Painting including toilet and kitchen
Kitchen Cabinet - Currently my hob and sink area is made up of concrete base/ builtup, will chemical cleaning or anything that I can do to restore it like
brand new ?
Custom Made Build-in Furniture - All laminates from Germany or Italy with solid ply wood
Kitchen Area
Design & fabricate top & bottom kitchen cabinet in laminate finish c/w 04 sides ABS trimming
swing doors, chioces of drawers, cuttlery tray, 02 pcs of glass panels & designer handles
(Length includes + top cabinet 26ft + bottom cabinet 17ft )
Supply & install stainless steel dish rack with hydralic system & glass panel
Supply & install solid surface worktop for kitchen cabinet
Design & fabricate full height tall unit cabinet in laminate finish
Supply & install soft closing hinges
Hi All,
Dismantling Works
Masonary works
Door Works
Plumbing Works
Miscellaneous
Clearing off debris
brand new ?
Kitchen Area
Hi there,
Welcome to Renotalk!
Happy Renovation!
Cheers,
Jaskel
Hi All,
Dismantling Works
Masonary works
Door Works
Plumbing Works
Miscellaneous
Clearing off debris
brand new ?
Kitchen Area
Hello!
hmmm... not more than 30k i guess. Need more details.
Happy Renovation!
Cheers,
Mike
Edited by mikeyong500
Hi Mike,
Please share your contact if the mentioned work is around 30K.
Thanks
Jay
Hi Mike,
Thanks
Jay
Hi Jay,
Just saw your post. Will pm you.
Mike
