Help In Our Quote Of 4Rm Floor
Hi fellow talk member, I am been a follower of renotalk. Recently we have chat with ID. I think the design said that using mirror and glass will make the design more expensive.
Our is a 4 room standard flat
Based On
WET WORKS
LIVING / DINING ROOM
Supply Labour & Materials To Lay 600mm x 600mm Homogeneous Floor Tiles 436 sqft 3,270.00
> Selection of Tiles: Up to $3.50 psf
> Includes: Skirting using Cut Tiles
3x BEDROOMS
Supply Labour & Materials To Lay 800mm x 800mm Homogeneous Floor Tiles 524 sqft 3,930.00
KITCHEN / YARD
Construct Tiled Cement Base (Sides Only) for Kitchen Cabinets 1 unit 180.00
Construct Tiled Cement Base for Refrigerator 1 unit 100.00
Construct Tiled Cement Base for Washing Machine 1 unit 100.00
COMMON TOILET
Supply Labour & Materials To Over-Lay Homogeneous Wall Tiles 1 area 850.00
> Selection of Tiles: Up to $2.50 psf
> Excludes: Border/Special Tiles
Construct Tiled Cement Shower Kerb 1 area 150.00
MASTER TOILET
CEILING WORKS
Construct False Ceiling/Light Boxes/ Light Holders **** Room, Dinning Room & Passage Way Area 3 areas 1,200.00
Construct False Ceiling/Light Boxes/ Light Holders At Master Bedroom Area 1 area 950.00
Construct Curtain Pelmet **** Room (Window Areas) 1 unit 150.00
Construct Curtain Pelmet At Master Bedroom (Window Areas) 1 unit 150.00
CARPENTRY WORKS
NOTE: Unless otherwise stated, all Carpentry Works quoted herein are constructed using Solid Plywood w/ Laminate/Veneer Finishes only. Where design/specifications include materials other than Solid Plywood w/ Laminate/Veneer Finishes, relevant charges will apply subject to further quotation(s) & confirmation.
BOMB SHELTHER (STORE ROOM)
Supply Labour & Materials To Install Designed Feature Door c/w Tea Mirror Finishing As Per Design Proposed 8 feet 2,360.00
LIVING ROOM
Supply Labour & Materials To Install Designed Feature Wall c/w Laminate & Tea Mirror Finishing As Per Design Proposed 9 feet 2,250.00
Supply Labour & Materials To Install Designed TV Console c/w Laminate & Tea Mirror Clad With Drawers As Per Design Proposed 8 feet 960.00
KITCHEN
Supply Labour & Materials To Install Built-In Kitchen Cabinets - High-Quality Laminate Doors w/ ABS Trimmings (Internal: Colour Polykern)39 ft run 4,290.00
> Includes: Choice from FULL RANGE of LAMITAK 2008/09 Laminates (Latest) (Excludes: Metallic Laminates)
> Includes: Selected Designer Handles/Knobs
> Includes: 1 Pc Aluminium-Framed Frosted Glass Door
> Includes: 1 Set Drip-Dry Dish Rack
Supply Labour & Materials To Install Built-In Tall Unit Kitchen Cabinet - High-Quality Laminate Doors w/ ABS Trimmings (Internal: Colour Polykern)
2 feet 540.00
Supply Labour & Materials To Install Granite Surface Top 17 ft run 1,870.00
> Includes: Standard Back-Splash & Front-Edge Profiling
Add-On: Undermounting of Kitchen Sink 1 unit 80.00
MASTER BEDROOM
Supply Labour & Materials To Install Built-In Full-Height Wardrobe w/ Laminate & Aluminum-Frame Frosted Glass/Mirror Silding Doors As Per Design Proposed (Interior: White Polykem) 12 feet 3,240.00
Supply Labour & Materials To Install Designed TV Console c/w Laminate & Tea Mirror Clad With Drawers As Per Design Proposed 5 feet 600.00
Supply Labour & Materials To Install Designed Full-Height Feature Wall Cum Bed-Head c/w Imported Fabric Or PVC Cushion Finishing As Per Design Proposed
9 feet 2,655.00
Supply Labour & Materials To Install Bedside Table 2 units 500.00
BEDROOM 2
Supply Labour & Materials To Install Built-In Full-Height Wardrobe w/ Laminate & Aluminum-Frame Frosted Glass/Mirror Silding Doors As Per Design Proposed (Interior: White Polykem) 7 feet 1,890.00
BEDROOM 3
MASTER TOILET
Supply Labour & Materials To Install Suspended Bottom Vanity Cabinets, Full-Length Mirror & Top Cabinets w/ Light Pelmet (Excludes: Light Fittings)
4 feet 720.00
Supply Labour & Materials To Install CRESTO Solid Surface Top (for Vanity Top) (Includes: Additional Height for Back-Splash & Front-Edge Profiling)
4 feet 340.00
COMMON TOILET
Supply Labour & Materials To Install Suspended Bottom Vanity Cabinets 4 feet 560.00
4 feet 340.00
LAMINATE FLOORING
Supply Labour & Materials To Install BERRY Laminate Flooring At Master Bedroom As Per Design Proposed (Includes: Skirting) 91 sqft 720.00
Construct Raised 6 inch Platform w/ Timber Structure At Master Bedroom (Subject to Min. 100 sq feet) 91 sqft 720.00
GLASS WORKS
Supply Labour & Materials To Install SandBlast Tempered Glass Swing Door (10mm) At Kitchen Entrance 1 unit 850.00
Supply Labour & Materials To Install SandBlast Tempered Glass Backing At Kitchen Wall Area 1 unit 650.00
DOORS, SCREENS & WINDOWS
ROOM DOORS / PD DOORS
Supply Labour & Materials To Install Venner Door C/w Lock Set For 3x Bedrooms & 2x Toilet Entrance Areas 5 nos. 1,500.00
SHOWER SCREENS
Supply Labour & Materials To Install Frameless Tempered Glass Sliding Shower Screen (Includes: Tower/Hand-Rail) At Common Toilet Area 1 unit 850.00
Supply Labour & Materials To Install Frameless Tempered Glass Shower Screen (Includes: Tower/Hand-Rail) At Master Toilet Area 1 unit 580.00
WINDOWS / GRILLS
Supply Labour & Materials To Install Aluminium Sliding Windows Grills (Powder-Coated) **** Room, 3x Bedrooms, Kitchen Yard Window & Grills
4 areas 2,500.00
PLUMBING WORKS
Labour to Install Shower Mixer & Shower Set 2 nos. 140.00
Labour to Install Toilet Wash Basin & Mixer 2 nos. 240.00
Labour to Install Bathroom Accessories (5 pcs) 2 nos. 160.00
Labour to Install Central Water Heater 1 nos. 150.00
Labour to Install Kitchen Sink & Mixer 1 nos. 120.00
PAINTING WORKS
Painting Works for Whole House 1 area 1,200.00
> FULL RANGE of Paints from DULUX/NIPPON
> Note: Painting Works is Subject to Max. of 2-3 Coats. Any additional coat(s) OR surface preparation required due to condition of wall(s) will be charged based on On-Site Assessment.
OTHER WORKS
Supply & Laying of Floor Protection w/ Corrugated Paper (Single Layer) 1 area 300.00
Washing of Whole House (General Cleaning) 1 area 250.00
Haulage of New & Raw Materials 1 area 300.00
Clearing of Debris 1 area 300.00
Any renotalk member care to comment ?
i think you can reduce the amount of work. Why would you want to lay tiles in 3 bedrooms then lay laminate in the master bedroom? isn't that repeated?
yes, mirror and glass will make the total cost go up and if you don't want to to pay so much, then try to reduce the amount of mirror etc. i calculated the price pfr etc, i think its quite reasonable.
WET WORKS Nothing much. Looks okays.
CARPENTRY WORKS
Supply Labour & Materials To Install Designed Feature Door c/w Tea Mirror Finishing As Per Design Proposed 8 feet 2,360.00 At $295pfr quite ex why not opt for partition with concealed wall? Much cheaper
LIVING ROOM
Supply Labour & Materials To Install Designed Feature Wall c/w Laminate & Tea Mirror Finishing As Per Design Proposed 9 feet 2,250.00 At $250pfr maybe can be cheaper...
KITCHEN
Supply Labour & Materials To Install Built-In Kitchen Cabinets - High-Quality Laminate Doors w/ ABS Trimmings (Internal: Colour Polykern)39 ft run 4,290.00 Probably cheap soft closing... check with them...
2 feet 540.00 Casement? At $270pfr maybe can be cheaper...
Supply Labour & Materials To Install Granite Surface Top 17 ft run 1,870.00 Check with them the origin of the granite... From china one cheaper, quality not as good...
MASTER BEDROOM
9 feet 2,655.00 Casement? At $295pfr maybe can be cheaper...
BEDROOM 2
BEDROOM 3
MASTER TOILET
4 feet 720.00
4 feet 340.00
COMMON TOILET
4 feet 340.00
LAMINATE FLOORING
Supply Labour & Materials To Install BERRY Laminate Flooring At Master Bedroom As Per Design Proposed (Includes: Skirting) 91 sqft 720.00 At $7.90psf... seems like Berry flooring quite ex... Issit the one showcase at Hafary? maybe can have cheaper alternatives...
Construct Raised 6 inch Platform w/ Timber Structure At Master Bedroom (Subject to Min. 100 sq feet) 91 sqft 720.00 Timber platform cheaper than laminate???
GLASS WORKS
SHOWER SCREENS
Supply Labour & Materials To Install Frameless Tempered Glass Sliding Shower Screen (Includes: Tower/Hand-Rail) At Common Toilet Area 1 unit 850.00 At $850 for shower screen really quite ex... almost twice of what i quote sia...
Supply Labour & Materials To Install Frameless Tempered Glass Shower Screen (Includes: Tower/Hand-Rail) At Master Toilet Area 1 unit 580.00 can be cheaper definitely...
WINDOWS / GRILLS
4 areas 2,500.00
PLUMBING WORKS overall can be cheaper definitely...
PAINTING WORKS $1200 is cheap but how many colors can you choose??? Better check on this
OTHER WORKS
Overall: Can be cheaper.
:yamseng: ,
Mike
Edited by mikeyong500
