kooky
K's Home
Hey HappyAng! We were told that we can move into the flat by May 10th, hope in the next 2 weeks or so, most of the reno will be completed with as little hiccups as possible :-)
Today, contractor sent me pictures of the washbasins and lever taps being installed.
This is for the common bathroom on 2nd floor
This is for the bathroom in the master bedroom
That's all for now.
Two more weeks. Will count down for u.. :sport-smiley-004:
By the way, ur vanity top in ur toilet using quartz also?
Thank you, thank you! :D
We can't afford to use quartz for the entire flat. Just solid surface top by Samsung Staron.
IC. Quartz very ex hor? Looking forward to more photos from ur renovation.. :yeah:
Yeah lor! If everything also want the top of the class, we will be bleeding profusely......haha
My definition of a home is a place where my husband and I looking forward to coming back after a day at work and a safe place for my child. I can accept some flaws/imperfection in the renovation since I am not trying to create/display a showflat :-)
We usually inspect the flat during weekends instead of daily as it is usually better to check it out when workers are not around and to avoid causing disruption to them. Will try to take some more pictures.
Edited by kooky
Window grilles at the dinning area is done up.
Window grilles in my daughter's room is installed.
Window grilles in Guest's room is also done up.
Aircon unit installed in Guest's room
Aircon unit installed in daughter's room
Aircon unit installed in master bedroom
At long last! The glass panels on 2nd floor are installed!
Image 1 - pardon the person being captured in the camera. He is none other than the man of the house :-)
Image 2
Image 3
glasspanel2flrp2.jpge
Image 4
Image 5
Edited by kooky
Thank you :-)
We were hoping to see the structure of the kitchen cabinets & drawers to be done up yesterday but then there is a delay again. Contractor said it will start on Monday.
Time clock is ticking away.......
In case, we changed our mind later to move furniture around, buying a TV console off the rack seems make more sense than custom-made one which cost more.
After spending hours in the shopping mall, we have decided on this (nothing fanciful but simple design) for our Ivory sofa set and walnut coffee table (FOC with the sofa set).
Edited by kooky
