flyersummer
Any Electrician To Recommend?
wow your electrician is really pricey. here's mine for comparison:
Supply and install 13 amp single point = $35
Supply and install 13 amp double point = $50
Supply and install 15 amp air cond point = $60
Add lighting point = $30
Install normal light = $8
Install ceiling fan point = $40
Supply and install SCV point = $60
Supply and install telephone point = $60
Supply and install heater point = $60
my electrician is from Zenterra Engineering. i'm spending $2.6K to re-wire my whole em.
Can I have your contact? Thanks!
Hi everyone, I am currently souring for electricians.
Can someone PM me Mr Quek's or Mr Ong's number, please!
Hello Forumers
My electrician do the following (materials included)
1) extra tv point with casting run on top of the skirting. ($85)
2) extra single power point with cover in master bedroom toilet. ($50)
3) swap lights (foyer and passwage way). ($20) (1 pt $10)
4) check living room light (spoilt). FOC
Ok for that?
Thanks.
Happy
Can I have the contacts?
  • Like 1
Can I have his contact pls
I engaged Ah Keong as my electrician for both my place when I moved. His workmanship is good, responsive, competitive pricing and he will recommend what lights to buy. If he feel that certain installation is not required, he will let you know. You can try contacting him at 9383-2155. No harm getting another quote
Hi, i engaged Ah Keong for my reno and think that his service is super duper. Very pro, just look at the ID's drawing and he knows what to do and dun even have to wait for the ID to be there to start work.
Initially, was afraid that he might get everything done wrongly but when the ID reach, she also surprise by his work. Very humble guy too.
MUST RECOMMAND!!!
Hi.
I'm looking for electricains to do up my electical works for my flat in aug.
Can I have Mr Quek's and Ah Keong's number too?
Thank you.
Regards
Raymond
can anyone please pm me Mr Quek's and Ah Keong's number
Hi hi, can I too have Mr Quek's and Ah Keong's number?
My contractor's electrican quoted me $1450 for:
1) installing 6 downlights in living room, 6 in dinning, 2 in MBR (no false ceiling required)
2) 1 double power point in lving room (change existing single pt to double pt, dining (extension of wiring r'quired) & kitchen (change existing single pt to double pt)
3) 1 single point in MBR (extension of wiring r'quired)
4) 1 cable vision point.
I got a shock when I saw the quotation..so expensive? So i ask for a breakdown and this is what I got:
1) power point single number - $50 / per no
2) power point double number - $55/ per no
3) Lighting points (as in wiring for downlights, exclude the downlight) - $40 / per no
4) installation of ceiling light - $25 / per no
5) cable vision point per no - $120
is it expensive? Is it standard to pay $25 for labour to change an existing light fitting to a new one ? My contractor told me its market rate?
