Is 43K Quote Reasonable For 5 Rm
Pls advise if the following $43K quote reasonable? If anyone got good contractor to recommend, let me know. I have a 5 rm hdb and a very tight budget?
5 ROOM RESALE FLAT
HACKING $2,500.00
Hacking existing cornices for whole house
Hacking existing tile flooring for Living and Dining
Hacking existing tile flooring for 4 Bedrooms
Hacking existing flooring for 2 Bathrooms
Hacking existing wall tiles for 2 Bathrooms
Dismantle existing accessories for 2 Bathrooms
Dismantle existing sanitary wares for 2 Bathrooms
Dismantle existing pipings for 2 Bathrooms
Dismantle existing electrical conduits for 2 Bathrooms/Kitchen
Hacking existing flooring for Kitchen
Hacking existing wall tiles for Kitchen
Hacking existing concrete cabinet base
Dismantle existing kitchen cabinet and 3 wardrobes
Dismantle existing skirtings for whole house
HAULAGE FOC
Haulage service & debris disposal and Provision of sand.
WET WORKS – TILING, (tiles price $3.00/sq ft) $15,000.00
Supply and lay Floor Tiles, 600 x 600 mm; including skirtings for Living & Dining.
Supply and lay Floor Tiles, 600 x 600 mm; including skirtings for Balcony.
Supply and lay Floor Tiles, 600 x 600 mm; including skirtings for 4 Nos. Bedrooms.
Supply and lay Wall Tiles, 300 x 300 mm/600 mm x 300 mm; for Master Toilet.
Supply and lay Floor Tiles, 300 x 300 mm/600 mm x 300 mm; for Master Toilet.
Supply and lay Wall Tiles, 300 x 300 mm/600 mm x 300 mm; for Common Toilet.
Supply and lay Floor Tiles, 300 x 300 mm/600 mm x 300 mm; for Common Toilet.
Supply and lay Wall Tiles, 450 x 300 mm; for Kitchen
Supply and lay Floor Tiles, 300 x 300 mm; for Kitchen. Including Service Balcony.
WET WORKS, OTHERS $950.00
Construct 50 mm H kitchen mortar cabinet base with side tiling works.
Construct 50 mm washing machine mortar base with full tiling works.
Construct shower mortar kerb with full tiling works in 1 no. Toilet
Laying of HDB Approved Waterproofing membrane for 1 no. Bathroom
Laying of HDB Approved Waterproofing membrane for Kitchen.
PLUMBING $1,870.00
Supply and replace stainless steel pipe for 2 toilets & Kitchen
Labour to install sitting water closets, 2 sets
Labour for installing Wash Basin & Tap, 2 sets.
Labour for installing 1 no. Storage Heater or 2 nos. Instant Heaters
Labour for installing Bathroom Accessories set, 2 nos.
Labour for installing Bidget/Hand Spray Set, 2 nos.
Labour for installing outlet pipe for Kitchen sink
Labour for installing outlet pipe for washing machine
Labour for installing 1 no. washing machine tap
Labour for installing 1 no. Stainless Steel Kitchen sink with tap
PAINTING $1,530.00
Paint whole Flat using Nippon Vinilex 5000 Emulsion paint. Total Colour 4+1.
Varnish / Paint all doors, door frames and exposed pipes
DOORS $1,800.00
Main Door: Supply & Install Solid Wooden Main Door in Laminate Finish, Non-fire rated, . With ABS edging
4 nos. Supply & Install Bedroom Laminate solid Plywood Door in Laminate Finish (3'W x 7' ht). With ABS edging.
GATE $500.00
Supply & Install Wrought-iron gate, 1000 mm L x 7' ht (double panels).
ALUMINIUM DOORS $400.00
Common & Master Toilets: Supply and install Toilet Aluminium Bi-fold door in white powder-coated Finish
SHOWER SCREENS $700.00
2 nos. Common and Master Toilet: Supply and install Shower Screen (1 Straight Fix Panel+1 Swing Door), tempered glass, 10 mm,
CARPENTRY – KITCHEN $6,615.00
Fabricate Top and Bottom kitchen cabinet laminate finish and ABS trim for doors edges. Length: 37 ft
Supply and install 1 set of 2 tier stainless steel dish drainer. All doors in soft closing hinges.
Supply and install solid surface worktop for kitchen cabinet. Length: 21 ft
Supply and install 6 mm Clear Tempered Glass Kitchen Back Splash with Spray Paint and plywood backing, 5 mm thickness.
CARPENTRY – BEDROOMS $5,260.00
Master Bedroom: 8 ft Height, Swing Door Wardrobe in laminate finish. Length: 7 ft. L Shape.
Bedroom 2: 8 ft Height, Swing Door Wardrobe in laminate finish. Length: 5 ft
Bedroom 3: 8 ft Height, Sliding Door Wardrobe in laminate finish. Length: 10 ft
Master Bedroom: Suspended Bedside Table Drawer Cabinet, in Laminate Finish. 2 nos.
CARPENTRY – TOILETS $2,760.00
Master Toilet: Vanity Bottom Suspended Cabinet in solid plywood and laminate finish. Length: 3 ft
Master Toilet: Vanity Top Hung Cabinet with Swing Door Mirror (top of basin), suspended in solid plywood and laminate finish. Door Edgings in ABS trimmings. 5 ft Length
Master Toilet: Supply and install solid surface worktop for Vanity cabinet. 3 ft Length
Common Toilet: Vanity Bottom Suspended Cabinet (in solid plywood and laminate finish. Length: 3 ft
Common Toilet: Vanity Top Hung Cabinet with Swing Door Mirror (top of basin), suspended in solid plywood and laminate finish. 3 Length
Common Toilet: Supply and install solid surface worktop for Vanity cabinet. 3 ft Length
CARPENTRY – OTHERS $1,150.00
Full 8 ft Height L Shape Shoe Cabinet with 500 mm Width PVC Leather Cushion Settee, 5 ft Length
ELECTRICAL $3,000.00
L Box, 5 amp Lighting Point c/w switch, Non-Concealed, 9 nos.
Installation of LED Downlights, Non-Concealed, 9 nos.
5 amp Fan Point c/w switch, Concealed, 1 no.
Install Ceiling Fan w/light kit, Non-Concealed, 1 no.
13 amp Single Power Socket, Non-Concealed, 10 nos.
TV Console: 13 amp Double Power Socket, Non-Concealed, 2 nos
SCV Point (SCV 1530 RG 6 cable), Non-Concealed, 1 no.
Telephone Point, Non-Concealed, 1 no.
5 amp Lighting Point c/w switch, Non-Concealed, 12 nos.
Install Hanging Pendent Light, Non-Concealed, 1 no.
Installation of Ceiling Lightings, Non-Concealed, 11 nos.
15 amp Hob/Hood Point, Non-Concealed, 1 no.
Labour to connect Hob in kitchen cabinet. 1 no.
Labour to connect Hood in kitchen cabinet. 1 no.
15 amp Heater Point, Non-Concealed, 1 no.
13 amp weatherproof single point, Concealed for washing machine, 1 no.
13 amp Double Power Socket, Non-Concealed, 10 nos.
CLEANING $700.00
Lay floor protection cardboard for 5-Room Flat
General Cleaning upon Completion
Chemical Washing
FREE PRODUCTS
2 nos. Crizto Classic High End Water Closet (WC or Toilet Bowl) for Common / Master Toilet
Crizto High Quality Double Bowl Stainless Steel Kitchen Sink complete with sink drainage trap
Crizto Kitchen Sink Cold Water Tap
2 nos. Crizto White Basin, Countertop or wall Mounted
2 nos. Basin Cold Water Tap, high end good design
2 nos. Crizto Rain Elevation Shower Mixer Set with hand shower set.
2 nos. Spray Bidget Set with Hose
2 nos. Spray Bidget Valve, normal
1 no. Supply Ariston Storage Water Heater, 25 litres
1 no. Supply and install Tall Pantry Pull-out System, 1600 mm H
Total: $44,735.00
Special Discount: $1,735.00
Final Total: $43,000.00
Edited by sitihad
  • 3 weeks later...
Hi Siti,
I can quote way better than that. Seriously the price is too high. I guess the profit margin that the I'd set is too high. For example the shower screen price that he quoted is $700 for a straight panel with swing door. What usually quoted for the same item is $580. Can you see the diff? I quote $780 to my clients for a L shaped shower screen. Baik u buat you punye research sekali lagi. Kalau nak tolong boleh contact I untuk more info.
Thanks and best regards,
Shan
[remove - signature - advertising]
  • 1 month later...
Hi, yr renovation quote looks reasonable to me? Can share me yr Id or contractor 's contact?
your quote looks reasonable leh... maybe can get 40k maybe...
anywayz your shower screen is for 2 nos right? S700 is okays la. cheap.
mikey
Hi Sitihad,
The quotation looks reasonable to me, possible to pm me your contact for the above quotation?
Most important is to and view the IDs or contractors works which they are renovating now. Also materials plays a part. Cheap with good materials then good. But cheap with a bad material then no point. Still need to see the responsible and the eagerness of the ID or contractor. Be safe then sorry.
Below are the comments on how I feel. If there is any offence, mine apologies.
Laying of HDB Approved Waterproofing membrane for 1 no. Bathroom - how about the other bathroom? Do not need any waterproofing?
DOORS $1,800.00
Main Door: Supply & Install Solid Wooden Main Door in Laminate Finish, Non-fire rated, . With ABS edging - best get a fire rated main door. u will never know what will happen in next 5 to 10 years.
CARPENTRY – BEDROOMS $5,260.00 - check with the ID or contractor how much is per square ft.
Master Bedroom: 8 ft Height, Swing Door Wardrobe in laminate finish. Length: 7 ft. L Shape. -
ensure the interior layout of the swing door wardrobe suits to your requirement. Also if the swing door it will take out more space of your room. If want can try to use curtains or open concept. This applies to your bedroom 2 and 3.
Master Bedroom: Suspended Bedside Table Drawer Cabinet, in Laminate Finish. 2 nos. - this can buy off the shelf.
Full 8 ft Height L Shape Shoe Cabinet with 500 mm Width PVC Leather Cushion Settee, 5 ft Length - ensure the door is soft close hinges.
FREE PRODUCTS - nothing is free in this world. always check the conditions on the products for any defects and cracks.
