My Kitchen Hood Delizia Not Working.
I have this brand Delizia a kitchen hood which the motor and light suddenly stop working. Model is Elislim.
I suspect is the fuse. How do I access to the fuse and cheaply replace the fuse?
Edited by Harry
If you think it's the fuse, there is only the one at the 3 pin plug.
Check there.
Hi Lee,
The switch for the kitchen hood is lighted. The switch is like those of water heater. So if you refer to the fuse in this fuse, it probably not this fault.
U don't even use a multimeter to test for current, so I don't think u are qualified to perform repairs base on your guesses.
I assume you meant that the switches for the fan & light are lighted, so there is current reaching them.
Try removing the filter/mesh and look behind the area where the switches for the fan & light are. There might be some electrical connection behind there. I am not sure if there will be fuses there but mine (not Delizia) is just simple wiring connection if I recall correctly (the last time I check; 3 year ago).
  • 2 months later...
