johnnychai
How To Nail Trunking On Concrete Wall
Use a long nose pliers to hold the nails while you use the hammer to knock,save ur thumb and fingers.
Another way is the use screws with attached wall plug>Drill your holes together with the plastic trunking and knock the screws with wall plug with a hammer straight.
5mm drill bit required for the drilling part.Ask DIY hardware store the kind of screw i mention,buy 1 box is cheaper than buy by loose pieces.
Edited by Freakerz
With OMO, not easy to hold trunking, nail, hammer.....at one time.
What i did, put thin double side tape on trunking......one hand hold nail, another with hammer.
Make sure steel nail, not iron nail. Application on concrete wall, i meant
