airbbb
Vinyl Floor As Feature Wall
Any advise in using vinyl floor tiles (stick type) for walls?
I can get them at $2 psft from my own source and DIY which is quite cost effective.
that's really cheap... but sticking it vertical on the wall... would it stick well ?
maybe you can try it out before going big bang...
I got someone to do a feature wall using nippon momento paint... pretty expensive... but nice .... originally wanted to do wall paper but didn't feel it would last...
you can use laminate flooring as feature wall. thats what i intended to use. its comparable to price of vinyl flooring but with a wide range of designs as well.
laminates using click-lock to join, shouldn't be a problem on the connection.
there are many suppliers of laminate floors. you can try supreme or evorich.
I imagine one would use construction adhesive to glue them to wall and an electric nail gun to nail the edge at 45 degrees angle. I still can't think of a solution to finish the edges as the sides of the edges will be exposed due to right angle wall
