millienium_bear
Replacement Of Downlight Led
need some advise..
thinking of replacing all the "tradition" downlight (those with CLF lights) with LED downlight..
receiving a few quotes from different lights shops, and nearly $800 including installation cost ($12 per light x 25)..
each LED downlight piece cost roughly $16-$20..
is it wise to replace all? will have problem after installing LED lights?
have been using traditional lights for 7 years++..
not sure if it will be cost-saving in long run when replacing...
Just work out the power consumption based on your usage pattern and see how long it takes to recover your $800 investment. The lifespan should be about the same between a CFL and a low end LED.
I need to replace fluorescent tubes every few months in my parents' house. In comparison, LED should last several years. For 25 LED downlights, the cost should be around $600 inclusive of installation, based on $14 per LED downlight plus $10 for installation that I got from Yafen LED Lights for my home. I have not bought from her yet because my renovation has not started but from my Google search, she is highly recommended because her lights are very cheap and very good.
Edited by spike
Guys i also interested in replacing the whole fitting rather than the bulb, which i think you both are taking about i want to replace the fitting so that, I can put instraight over top,
