DIY Cleaning StarMEX Indoor Unit
Anybody has any idea how to remove the blower of the indoor unit? My model is MSY-GE10VA.
I'm able to remove the drip tray and all the electrical section on the right. When attempting to remove the blower, I was able to remove the left side (which just sits in a bearing housing). On the right side, I had loosen the screw that connects the blower to the motor. I could slide the blower in the left, right direction, so it should be free.
So I tilted the cooling fins outwards, lower the left side of the blower till it clears the cooling fins and tried to slide the blower towards the left. It t slide for about 20mm and stop. It refuse to come off the motor shaft. No matter how hard I pull, the right side does not want to disengage from the motor shaft. I dare not move the cooling fins too much in case I damage the refrigerant tubing.
Anyone has any DIY experience? Thanks in advance.
  • 4 weeks later...
Its a simple thing to do see the below videos Part 1& Part 2
Part 1 Below
Part 2 Below
  • 3 weeks later...
