Not all new condominium has gas pipes?
Hi. I have always been using piped gas in my existing condo, so when I found out that the new condo that we are moving into does not have City Gas pipes installed and the only option is to use LPG cylinder, I'm taken aback. Who decides if gas pipes should be installed in an estate?  Is there really no alternative other than LPG cylinder? Tks.
The developer decides.
having gas pipe is not a statutory requirement. Not all areas have gas mains nearby and it cost a bomb to lay a connection.
Units with no seperately ventilated kitchens.. Such as studios require elaborate gas leak detection devices.
There are alternatives to LPG....
You can use the Mayer Hybrid Hob. It has vitro ceramic and induction. Perfect combo.
  • 3 weeks later...
  • 1 month later...
