Peter yoke 0 Report post Posted August 17, 2018 I want to do wall drilling in my HDB flat,can anyone recommend me what brand n good quality drill bit?where to buy it? Share this post Link to post Share on other sites
snoozee 97 Report post Posted August 23, 2018 any neighbor hardware stores will sell the bits. else you can go to self-fix or homefix to buy the bits. make sure you get the correct type of drill bits for drilling walls and you have a hammer drill as well. if you are planning to drill tiles, buy the type of drill bits for drilling tiles instead using the masonry bit for drilling walls. set your drill to normal drilling mode instead of hammer drilling mode. this will miminise the chances of cracking/chipping the tiles when drilling. after drilling through the tile, change to the masonry bit to drill the wall behind the tile so as not to damage the tile drill bit. most contractors can't be bothered to use a tile drill bit when drilling the tiles in toilet or kitchen and cause cracks/chips on the tile. Share this post Link to post Share on other sites
Karoline 18 Report post Posted September 4, 2018 On 8/23/2018 at 12:14 PM, snoozee said: any neighbor hardware stores will sell the bits. else you can go to self-fix or homefix to buy the bits. make sure you get the correct type of drill bits for drilling walls and you have a hammer drill as well. if you are planning to drill tiles, buy the type of drill bits for drilling tiles instead using the masonry bit for drilling walls. set your drill to normal drilling mode instead of hammer drilling mode. this will miminise the chances of cracking/chipping the tiles when drilling. after drilling through the tile, change to the masonry bit to drill the wall behind the tile so as not to damage the tile drill bit. most contractors can't be bothered to use a tile drill bit when drilling the tiles in toilet or kitchen and cause cracks/chips on the tile. Would agree with this totally, good advice Share this post Link to post Share on other sites
home05 0 Report post Posted October 21, 2018 You will need to decide what drill bit size to buy and the corresponding anchor size that will fit into the drill hole. I suggest using a 6mm drill bit as a start. Share this post Link to post Share on other sites
WordSmith 45 Report post Posted March 7, 2019 (edited) On 10/21/2018 at 8:56 PM, home05 said: suggest using a 6mm drill bit as a start That is actually a good idea because i think the last thing anyone would want to have is hole patches so start with a small hole first and then work your way up if needed Edited March 7, 2019 by WordSmith Share this post Link to post Share on other sites
CharSiewPau 60 Report post Posted October 5, 2019 When buying a drill bit TS always remember to buy the red tipped ones in your case Share this post Link to post Share on other sites
kaykey 0 Report post Posted November 14, 2019 the sellers at hardware stores may give you some useful advice too! Share this post Link to post Share on other sites
