galliano
Video Intercom @ gate
Hi all,
Looking for recommendations for video intercom systems @ main gate. Figured these days its all wireless and should prob be able to link up to an Amazon Echo Spot or similar. For my gate, i have catered a single gang power socket and a Cat 6 outlet.
On the brink of doing some "smart" systems with perhaps some singular cams in living room & kitchen, but figures i keep my options open 1st. But getting an intercom as a start.
Any suggestions? Thanks in advanced.
video intercom systems usually operate on low voltage DC so there's actually no need to pull a 13A socket for your gate.
normally there will be a master device with video screen in your house and this is powered from the mains via a power adaptor and a cable is then used to connect the doorbell/intercom/video cam at the gate.
my suggestion is to search and finalise on the particular video door bell you wish to get for your house then plan the correct wiring for the model of the system you're getting.
Have been searching around abit online ... most recommended Ring (https://ring.com/). The Ring 1 is on offer @ USD99.
Looks easy to use, and practically no wiring involved.
Edited by galliano
this Ring is installed at the front door. doesn't seem to have IP65 as well so if you want to install at your gate, need to build a case for it. then also the question is whether your home WIFI can reach the device which is enclosed in a casing and located about 10m from your WIFI router or not.
Edited by snoozee
Re-igniting this thread again on video intercom.
Considering its Black Friday weekend, been busy looking at the deals.
1, Google Home Hub (Home Hub now on offer USD99)
2. Video intercom with doorbell (Nest Hello USD179)
I guess for me, i would really want to
- have everything on Google ecosystem so at least its scalable
BUT, my concern is how my gate remote control can be linked to Google ecosystem. My contractor says its a hard wire connection basically to trigger the lock/unlocking of the front gate. Anyone has experience?
I don’t think have anything off the shelf that can do what you want. But it is technically possible with some custom IOT hardware to interface with the gate hardware.
For me, I just purchased a set of video doorbell with 4 video monitors and it also comes with electrical lock for gate with a remote controller to unlock the gate or can use the video monitor or video door bell (with access key/card) to unlock. All are hardwired from inside the house to gate. Entire setup cost me less than $500 from AliExpress.
  • Like 1
Thanks. That’s the ‘missing link’ that’s puzzling me. But it can’t be that rare request.
Thanks for the heads up bout yr purchase. Can PM me the details?
I ran into the same issue when I was trying to find an intercom system that would integrate nicely with my smart home setup. Everything seems to be separate unless you're willing to tinker with some DIY solutions, especially when it comes to linking the gate lock directly to Google Home. My setup ended up being a mix of older wired intercom and a WiFi camera, but the one-touch remote unlocking from Google Home or Alexa is still tricky without investing in custom automation stuff. If you’re planning to keep everything on the Google side, you might need extra relays or smart controllers that trigger the gate lock by hardwiring, which isn’t straightforward. For guides and how-tos on setting this up or recording demo videos for your contractor, I’ve used https://www.movavi.com/screen-recorder/ for reliable tutorials and screen captures to share with others.
Hi Snooze,  can share the link to purchase?  I need to put in 6 monitors in the house and a weather proof system that is durable.  The system needs to be able see the person at the side gate with video and audio + able to remotely open the door and for occupants of the house, a finger print access or face recognition access is needed.  If for some reason, it fails to identify, access can be by touch number pad.  The hard wired system should also be able to programme for free access on certain days and "operating hours" to allow access.  You have lobang for such a system?
Preferably, the system can also do video recording.  If the system cannot do all of it together, I am ok to have separate systems working together.  Prefer not to use wifi as the distance from the wifi to the gate can be about 30m to 35m away and wave transmission may be hindered by multiple walls in between.
Edited by leechaorui
