Glow Tape And Auto-sense Light
Anyone knows where to get those glow tape that can glow in the night?
Also, would like to find out anywhere that sells the movement sensing switch that can be diy installed onto light socket.
movement sensing lamp? or movement sensing switch?
only 2 types i saw -
1) battery operated
2) security lights (light points)
  • 4 months later...
Ok, for all who are interested.
I got my glowtapes from the Arts and Friends shop in Bras Basah.
Also, I got the PIR sensor that can be directly added to any lamp in a basement shop Sim Lim Tower.
  • 1 month later...
can you elaborate alittle on how the PIR sensor works with any lamp? Can share the name of the shop and price of the sensor? Thanks!
Basically, the PIR sensor cuts off the power to the lamp. When it senses movement, it will "allow" power to go to the lamp thereby activating it.
Can't remember the shop's name. Its one of the bigger corner shop at the basement. You can identify it by the many LED flashing lights. I'm planning to get 2 more units from him.
  • 1 month later...
hi, can you advise how much did it cost you and if it works well?
I thought of getting motion-sensor-light initially as well but eventually decided to get this...
Philips LED Candles
the LED light fickles like a candle and its not too bright so perfect for walking around in the dark with the lights off. Also, it doubles up as nice candle light display without the hassle of an actual candle. !!
:dancingqueen:
Edited by niwdehos
Philips LED Candles
:dancingqueen:
ya cheap and good - just change battery. !!
ya cheap and good - just change battery. :bow:
Well, even better, the set sold locally by HN, Carrefour, Courts comes with a base charger, charge it full and the light will fickle and last up to 13hrs before needing another charge.
me got this to stick on the walls of my pathway
good for going to the toilet at night :(
it's a motion activated infrared LED light, using AAA batteries
when we move towards it, it will light up and go off after 20sec
cost $20 each :bow: :bow:
Edited by applefreak
good for going to the toilet at night :P
cost $20 each :deal: :deal:
where u buy it?
aiya should have come here and jio
maybe can get even better discount if buy more :dancingqueen::yamseng:
wa! really nice intro here!:dancingqueen: both PIR & philips look good.. idea idea leh...
