Black Line Between The Laminate Edges
Does anyone know how to remove the blackline in between the laminate edges?
My laminate is maple colour, and all the edges in between the laminate edge have a black line....
Please advise...
Thanks!
My laminates are black / dark grey..
I think the carpenter simply used a black paint marker to draw over, if you can find maple color or something close, should be done the same way..
Maple colour marker may not be able to colour black line ( lamins base colour )
Not sure .... can still try ... better use oil base type
Hmm, I like light color laminates.
I found out that the carpenters can do some "patching" use some form of "putty" (hope i et it right) to fill up the "black lines" or if not you can asked for ABS trimming else there are some laminates with with base but will be much more expensive.
hope this info helps.
but check with your ID/renovators...one thing for sure, can be resolved though may not be 100% like those you get for verneer edges.
Cheers
Thanks Guys!
Actually would love to use ABS trimming. They are using ABS trimming only for the doors of the drawers. Because ABS trimming only comes on a small width i guess....
They installed the console, so I can see the black lines, it's a bit hard to change to veneer edges / anything more expensive, I guess, i have to find my own way... either paint it over or do something else... :D
