Aircon Quotes (From Aron)
Please quote me Mitsubishi Starmex system 4 (10K x 3/ 18k x1) and (10k x 3 / 24 x 1). And whats the details. ThankS!
  • Replies 2.1k
  • Views 660.4k
  • I was told my a saleman selling aircon that the default grey insulation is good enuff if your aircon trunking is expose as most of the HDB are. And not hidden as those in the condominium. Armaflex ar
  • ok, there are retailers who try to cut corners to save $$. eg. they offer you system 3 at (est) $3.4k, generally the air-con mfgr specs will specify wat type of material to use, eg. for insulation, pi
  • i got a quote from gain city. Mitsubishi invertor, compressor is 30k btu, then 3X 9k units for 3 rooms, and a 22k unit for the living area. Cost is $3.4k. is it cheap? TO be honest, im a noob when it
hi,
can quote me for panasonic and starmex system 4 pls.
cheers
hi pls pm for
mitsubishi inverter system 2 for 2 bedrm, pls include bracket as it is for an old 3rm flat.
mitsubishi inverter system 3 for 3 bedrm + system 1 for 5rm living. (my new home)
thanks.
I have just PMed to you.
Thank you,
Aron (aronputt@gmail.com)
Hello , can I get for PM quotation for
1. Mitsubishi Starmax Inverter Sys3
2. Daikin Inverter sys3
3. Fujitsu or any other brand.
currently surveying for models
House is Old 5 RM Flat in Yishun
Thank you,
Hi, can u also quote me for Mitsubishi starmex inverter system 4( 1 living room and 3 bedroom- pls list the BTU? ) And how is the warranty?
Thank you,
Thank you,
hi,
cheers
Thank you,
Hi, can pm me the price for starmex system 4 and system 3 with 1 other single split unit. Tks.
Edited by Szc
Would like to get quote for starmex system 4 as well (3 bedroom and 1 living room).. thanks!
May I find out based on your experience, which of these brands less problematic & easier to service? Toshiba, Fujitsu, Mitsubishi Heavy & Mit Electric.
I'm considering system 3 from
a) Toshiba RAS3M20SACV +RASM10SKCV x3 (cos Made in Japan Condenser, but does it really matters?)
b) Fujitsu AOAG24LAT3 +ASAG09LJ x3
Pls kindly PM me asap. Thank you.
Edited by jjsk88
Hi Icebaby,
Kindly drop me an email at derrick.tan@atomtrd.com and I will forward you the quotation.
Thank you and looking forward to hear from you!
Regards,
Derrick Tan
93682128
Hi Aron,
can you pm me your quote for the below:
4. Any other brand you recommend for typical new 4rm flat (need just for the 3 bed rooms)
Thanks.
Hi Aron,
Could you kindly quote me the following from Mitsubishi Starmax Inverter:
1 x 24 BTU
1 x 18 BTU
1 x 9 BTU
or
1 x 24 BTU
3 x 9 BTU
Please also quote with the following requirements (mostly which you have already stated except a few others):
1. Using of "4c70" control wiring. (From Keystone)
2. Class "0" and 1/2 inch thick insulation (From Yamato)
3. G23 copper pipe
4. 16mm drainage pipe
5. 2 installation trips
Thanks alot.
Hi Aron,
Can you pm me the quote for Mitsubishi Starmex Inverter for 3 bedrooms? Please also include installation details and warranty. Thanks!
