Need Mr Chong Kind Advise On The Layout.
Hi Mr Chong,
Need your advise on my following floorplan. The bedrooms are facing the south my masterbed room is facing south east and living room south west.
I have a divider at the living room feature wall to block the "Qi" been flow straight out thru bedroom 2.
Awaiting for your kind advise. Tks! :D
Hi Mr Chong,
Hello
Not much advise right now until you followed my pinned instruction and give me the compass readings.
Try to draw a pic of your access balcony/corridor and indicate to me the lifts and stairs. Or take pics and load up here.
Building the partition in your Q bed makes the room a bit cramp. It is not good to have an edge of the partiton still in line with a part of the Q bed.
Living room partion should not be that far away. It would be better if the horizontal partion is at the other end of your L sofa.
You should anyhow put a water feature. Is there any reason why you draw it there?
  • 1 month later...
Hi Mr Chong,
My floor plan is the same as mos_burger. (Hi neighbour of #344) I am also worried about the "Qi" flowing from the main door through the lving room and out of bedroom 2 as the corridor outside the main door is an airwell (Low wall).
On top of that, from the master bedroom, there are 3 doors in a row (From MBR toilet door to MBR door to BR 3). Is this good under FS terms esp when it's toilet door facing the 2 bedroom doors?
Lastly, I understand that our fridge should not face the toilet door as it's food facing filth. Is there any way I can do adjustment if the fridge really must face the toilet door due to space constraint?
Greatly appreciate your advice.
Thank you.
Hi Mr Chong,
Thank you.
Hello
Floorplan the same doesn't really matter. If you need advice, read my pinned instructions. This is because the compass direction for every house is different.
If door arrangements not good, then remedies recommended will also have to depend on your compass readings.
I think I have one post regarding the same issue about fridge like yours. The recommendations are there.
