wuga98
Stair Landing Length
anyone know what is the normal length of the stair landing from wall to handrail? I know there is a min requirement from authority but generally what will your architect or ID person tell the main con to construct.
:dunno:
Thanks.
Thanks, is there an issue bring furnitures up to 2 or 3 floor if you have length of 900 to 1000mm? Thanks. :dunno:
min is 900. But for comfortable 2 ppl passing up and down, is 1200mm
I think the most important part is the landing between 2 stairs. If it is too narrow then it is hard to turn the furniture. There must be enough space (bigger squarish area) for furniture to turn around. IMHO.
The issue is whether u design the stairwell to be like a tunnel, where there is a wall between the 2 flights, or is the old fashion stairwell, where there is no obstruction between the railings. So can easily lift up bulky stuff over the railing between 2 flights.
The tunnel look is popular these days, as ID can make the transition from 1 floor to another floor look very different, dun have to have same colour stairwell walls across all the floors. Also for floor to floor aircon partition purposes.
