andy_sg_123
Rooms & Letterbox Locks
difficult to explain. Room one u have to change the whole nob. When u go and buy a new one, u can also ask that person how to change.
letterbox normally use cam lock; about 1.50, buy the one with 5 nos of key - master lock, a few bucks.
Open your letterbox and see behind the lockset, u can there is hex ring screwed to hold the lockset onto the panel. U need a hex flat spanner, the thk not thicker than the ring to fasten & unfasten the ring.
Alternatively, u a wide pier, wide enough to hold the ring
Hi Gladys, can let me where i can get the letterbox lock? thanks
Letter box lock, go to those hardware shop also will have.
Home-Fix also haf.
Do note it comes in different lengths.
Different letter box fabricator uses different lock. Bring your existing lock along.
Most hardware shop in the ind est do have this. The dia & the length of the shaft has to be the same as your existing. The plate can be shorten buy using a hack saw plate.
Cam lock is known as 钩 锁。
U can get it at the following: Kim Men, seawalk, thye seng, xin huat, power j, fupizat, Blk 22 woodlands link, blk 5024 amk and kaki bukit etc...
view this: www.seawalk.com. - Architecture ,- locks - cabinet locks; Jasmine cam lock 607/25; the cylinder core is 25mm long, - jasmine c l 607/30 is lenght 30mm
Edited by gladyslim
Your picture is very disgusting.
If you don't mind, pls change it to a nice one.
No offense pls.
instead of paying $20 to $35 for a handyman to change the lock, i bought a cam lock from the shop opposite Sim Lim Tower. It costs me $2. Homefix sells their for $3.50 and also one for $36!
Just a adjustable spanner to unlock the nut holding the lockset and fit in the new lock. But the moving plate is too long so I just bent it to the correct length. Took me less than 15 mins. :)
anyone know of a good locksmith who can put in a new lock for a very old HDB gate? thanks!
Just my experience...
Most Yale cam lock turn in one direction so cannot use.
The moving arm of some cheaper locks used for locking drawing may be too long for use in the letter box. So, need to saw off the excess portion.
I think the simplest way to change letterbox lock is to check with your town council first (see link below).
http://www.amk-ycktc.org.sg/index.php?opti...2&Itemid=62
