City Gas Rinai Heater
Is this consider Storage Heater or Instant Heater? As it seems to be have both their features?? :dunno:
only instant gas heaters are approved for HDB use
so if this is the hdb version, then it's instant :yamseng:
Really? But you see the specs as below...don't seems like a Instant Heater leh.
REU-8 CG Gas Water Heater
Do you often have to waiting for some time to get warm water for showering or to fill up the bath tub for a good stress-out soak? Well, with gas water heater, you will be able to enjoy instantaneous hot water anytime you need!
FEATURES
- No storage tank required
- Water is only heated on demand, no storage tank is required to heat and store the water.
- Instantaneous and continuous flow of hot water
- Just set the heater at your desired temperature. All you need is to turn on the tap and unlimited supply of hot water is available for your usage.
- Availability of hot water at multiple point
- Able to supply hot water to 2 shower points in 2 separate bathrooms concurrently.
- Ease of operation
- User-friendly in design and usage.
- Batteries operated, no electricity required
- Do not require any electric supply thus no wiring required.
- Built-in safety features
- Giving peace of mind to users with built in overheating protection, flame failure and incomplete combustion devices.
- Low running cost
- Gas tariff is typically lower than Electricity tariff by about 20%*, thus you save more using Gas.
- Compact in size
- Slim and compact design that fits well in the kitchen or yard space with no exhaust flue required
SPECIFICATIONS
Model: City Gas – Rinnai REU-8 CG
Colour: Metallic Silver
Dimensions: H 372 mm x W 290 mm x D 136 mm
Hot Water Capacity: (Raised 25 degree celsius)
Max. Hot Water Volume: 8.0 L/min (water pressure 50 kPa)
Min. Hot Water Volume: 3.0 L/min (water pressure 50 kPa)
Min. Operating Water Pressure: 0.20 Kgf/cm2
Automative Spark Ignition: Yes
Gas Consumption: 37.7 MJ/h
Weight: 5.7 (31) Kg(lb)
FEATURES
- Ease of operation
- Low running cost
- Compact in size
SPECIFICATIONS
Yo Bro,
It is a instant heater.. see abv in blue and bold..
You only get hot water from storage heater in approx 15 mins because it needs to heat up the water stored in it..
yah loh, those in blue and bold points to a instant heater mah
all cannot be done by storage heater :notti:
  • 1 month later...
i know this question was asked before but seem like those are a different model compare to the one posted on citygas website. Anyone use the latest model? Any complain?
Anyone use this REU-8 CG GAS WATER HEATER
Any feedback, is it good? I mean by the waiting time? Is it better than storage heater?
For this, do we have to lay cold and hot pipe for this?
Just to ask again.. this one really have to wait for 15 minutes for the water to heat up is it?
hi,
i also thot of installing this as its on promo nw, ending 31.12.08. but my reno wil only begin in mid-jan. :(
its wifin our budget, considering its $168 incl of installation. quite cheap rite??
if you are staying in a hdb flat then the answer is no
only the instant model is allowed for use in hdb flats
however, if you are staying in a private property AND taking the storage tank models
then you got to wait for the water to heat up
why it takes a while to get hot water from your tap is because the cold water already in the pipe needs to be pushed out
so if the tap is right next to the heater, it'll take something like 3 sec to feel the water heating up :notti: :notti:
I am staying HDB, citygas technical came to my house say I am able to install. I am just trying to find out, will I have to wait long for the hot water while having my shower.
If the pipe is 7.7m away from the gas heater point, how long will it take?
i'd give about 30 sec :dunno: :dunno:
currently will fill a big red pail of water before it's steaming hot
using the water to wash my wc so no wastage there :notti:
30 sec.. you mean for my 7.7 m hot water piping is it..
