November 29, 200817 yr Hi all, Got a question on drilling wall. Usually pple will drill, then hammer a plastic thingy into the wall (to hold the screw more securely), then finally screw in. 1) what is the size of the drill bit to use for drilling? 2) what's the official name of that plastic screw holder thingy. 3) I've seen slightly different designs, different colour (red, green) of that plastic holder. Are there different in purpose, and size? Thanks in advance.
November 30, 200817 yr 1) The size of the drill bit will depend on the screw you will be using. Remember to use the right drill bit depending on the type of wall material you are drilling into (see point 3). 2) Should be a wall plug. 3) Different diameters to accept different screw size. Wall plugs are also differentiated between those designed to be used in solid walls (concrete, brick, mortar etc) and hollow walls (plasterboard, plywood, gypsum etc). Got to use the right type to ensure proper securing. I don't really like the generic red/green types. Not as well designed as those from Volkmar etc. that you can get easily from either Self-fix or Homefix.
November 30, 200817 yr Hi all, Got a question on drilling wall. Usually pple will drill, then hammer a plastic thingy into the wall (to hold the screw more securely), then finally screw in. 1) what is the size of the drill bit to use for drilling? 2) what's the official name of that plastic screw holder thingy. 3) I've seen slightly different designs, different colour (red, green) of that plastic holder. Are there different in purpose, and size? Thanks in advance. I think you mean wall plug or rawl plug. Maybe this link could help you http://www.ultimatehandyman.co.uk/F&F_WALL_PLUGS.htm Edited November 30, 200817 yr by alan26
December 1, 200817 yr If u are refering to those about the size of 1" x dia 8mm, availiable in wood, nylon - white opaque, red and dark green etc, that is 'jute' Another optiion is the nylong plug that is normally use in hanging lighter object like the wall suspension kitchen cabinet. For false wall partition, u got to use 'butterfly' nylon plug - about $1.20/pc. This u need to buy the applicator which is about $15/-, something like the one for riveting.
December 2, 200817 yr get those Masonry drill the plastic thing should be call wall anchor or something.. go home fix they will advise you
December 14, 200817 yr Hi all, Got a question on drilling wall. Usually pple will drill, then hammer a plastic thingy into the wall (to hold the screw more securely), then finally screw in. 1) what is the size of the drill bit to use for drilling? 2) what's the official name of that plastic screw holder thingy. 3) I've seen slightly different designs, different colour (red, green) of that plastic holder. Are there different in purpose, and size? Thanks in advance. Heavy item use larger diameter masonary drill bit and matching plug Light item use small diameter masonary drill bit and matching plug
