Kitchen Cabinet Top & Bottom Question
I do not understand below quote, Is the material using cheap pvc finish?
Any different between 11.5ft and 10ft? Top is 15ft or 11.5ft?
1 Design & fabricate L-shape kitchen cabinet complete with: $3155
a doors in selected laminate finish and ABS trimmings
b (L 11.5 ft) top & (L 15 ft) bottom cabinet internal carcass in white pvc finish
c 01 nos of Aluminium frames with sandblasted glass door
d box up drainge pipe
e s/s dish rack
f 01 pcs 5" x 60" solid surface top, $262
g installation of hob, hood (item supply by owner)
I SOLID SURFACE
1 Supply & install solid surface top at kitchen cabinet 15ft L, $1050
can any advise me.
item (b) meant the internal of the cabinet will be using the normal white PVC instead of fanciful/coloured laminates. the exterior of the cabinet u can still choose laminates of your choice. hope that helps.
e s/s dish rack
I SOLID SURFACE
can any advise me.
What is items f for? It is backsplash?
