Pls Help Me See If The Quote Is Reasonable :)
Hi all,
First time doing reovation here. Got a quote after some searching. Moeny is still tight and do not want to spend so much on a three room flat. already not putting whole wall tiles for kitchen ( leave as half)
I did not include all the items as we are still revising it. Just the major ones here. Also the taps, hood, hob, toilet bowl, lights all not provided. Its 20K already.
Hope to get your valuable input and any ideas soon!
Supply & lay 600x600mm polished homogeneous floor tiles for living , store & 2 bed rms with skirting. $3298
03. Supply & lay 300x300mm homogeneous tiles for kitchen floor. $830
05. Supply & lay 300x300mm non-slip homogeneous floor tiles for 2 toilet. $800
06. Supply & lay water proof membrane for 2 toilet. $200
08. To convert squart bowl at kitchen toilet to sitting bowl. $250
09. To replace existing water pipe for kitchen & 2 toilet. ( copper pipe) $680
10. Supply labour to install 2 toilet bowl , 2 wash basin , toilet accessories , taps & instant water heater. $350
11. Supply & replace rubbish chute to s/steel chute , flat type. $150
12. Supply & plastering smooth for wall & ceiling. $1300
13. To hack holes for living & bed rms floor , hack skirting , hack all wall & floor finishing at kitchen include sink dapoh & $2000
support , hack 2 toilet wall & floor finishing , supply sand , materials haulage & debris removal.
14. Electrical work , Re-wire , a) 09 nos. new lighting point $252 $1952
b) 08 nos. single power point. $400
c)04 nos. double power point $240
d) 03nos.SCV point $240
e) 03 Tel point. $120
f) 01 15amp air con point. $100
g) 01 heater point. $80
h) labour to install lights , 09 nos. $90
i) 3 core wire from hood to switch. $70 if required *
j) Earth point. $60
k) D/B box. $300
05. SUPPLY & INSTALL 25FT KITCHEN CABINET , SOLID PLY LAMINATED WITH ABS TRIMMING DOOR, $2590
WITH 1 NOS. S/STEEL DISH RACK.
06. SUPPLY & INSTALL 15FT SOLID SURFACE WORK TOP. ( COLOUR : BL019 ) $975
09. SUPPLY & INSTALL WROUGHT IRON GATE , 3’X7’ , DESIGN WS772 . $380
10. SUPPLY & PAINTING WHOLE HOUSE , ICI OR NIPPON , INCLUDE DOOR FRAME & PIPES. CEILING WHITE ONLY. $950
11. SUPPLY & INSTALL 2 NOS. CLASSIC DOOR , COMPLETE SET WITH SILVER DOOR KNOBS & MAGNET STOPPER. $300
12. SUPPLY & INSTALL MAIN DOOR , SOLID TIMBER DOOR , COMPLETE SET , VARNISH TONE E3 , WITH PRESS LOCK. $380
Hi wendy8,
I think the quote doesn't include price psf for the homogeneous tiles right? I'm going through this process as well now and saw on average ~$2.60 - $3.00 psf.
Hi wendy8,
yes. the contractor didnt specify on price psf. I find the cupboards also rather pricey since there is no price psf also. shd i get a carpenter to do it instead? if separate then get tiling done first then cupboard? or else sure got gaps yea?
Hi wendy8,
Sorry I'm not so sure myself on your questions. I'm pretty new at this too and just about to go through the same as you did here :) Doing as much homework as I can now. Good luck to you!
Hi all,
j) Earth point. $60
k) D/B box. $300
As a whole, i feel its reasonable. :)
Yes, be prepared to factor in another lump sum (perhaps $5-10k) on accessories, such as those u mentioned, the taps, hood, hob, toilet bowl, basins, lightings.
Remember to watch out for the GST component too. :)
hi wendy, overall the quote seems quite reasonable.... it is quite similar to the quotes i gotten for my reno.... currently doing the tiling works :)
however you might want to check what is the price range of tiles you can choose from....
with regards to the kitchen tiles, i had wanted to forego it also.... but my ID suggested that i keep the part that is going to be hidden by the kitchen cabinets and replace the exposed ones.... for the exposed part between the top and bottom cabinet, use tempered glass to cover them as a design concept....
it saved us around 1000... on the hacking and re-tiling :)
Hi Wendy8,
Can you PM me the contacts of your ID/contractor? The quotation looks reasonable!
Thanks!
garion, your ID help you save cost using logical sense...Nice! :good:
but using tempered glass to overlay sufficient meh? what if the old tiles pop out
or crack etc? will it have any affect on the glass overlaid?
Edited by El Nino_Al Nito
hi, yes we did raise this with the id... tempered glass can withstand great pressure without breaking, and force exerted by tiles poping out is not great..... everything is sealed in so you would not know if it cracks.... same as fitting the cabinet over the tiles.....
and even if the overlaying is on the new tiles... there are also possibilities that they will crack.... :)
Hi all,
j) Earth point. $60
k) D/B box. $300
Hi, this is mine...
1) Master Bedroom
- Custom make 8.5 ft (L) full height wardrobe with sliding door + finishes with solid plywood, selected laminate, mirror and ABD trimming door
- Custom make 1 set of suspended king size bed frame with storage compartment, side table, bed head and finishes with solid plywood, selected laminate, cushion and lighting point
- Supply and install 1 13A x 2 double socket
- Supply granite top 10ft(L) at bay window
- Curve False ceiling + cove lighting
- Install 1 light point at planter
- Change toilet bowl
- 2 wall colour
- 5 lighting points
- Additional 1 double socket
2) Bedroom 1
- Custom make 6ft (L) wardrobe with sliding door (specs same as above wardrobe)
- Custom make 6ft (L) study table with drawers
- 3 units of suspended books cabinet 6ft (L)
- Supply 2 13A x 2 double socket
- Supply granite top 6ft (L)
- Supply labor to install 1 light fitting
- 2 wall colour
- Additional 2 double socket + 1 single socket
3) Bedroom 2
- 2 wall colour
4) Living and dining area
- Custom make 5 nos shelving inside DB box
- Custom make 14ft (L) designer TV console finishes with solid plywood, selected laminate, colored glass panel and ABS trimming door
- Designer area using gypsum board, finishes with plaster and paint
- False ceiling + light box + cove lighting for living and dining area
- Wall mirror feature for dining area
- 10 lighting points
- 1 wall colour
5) Others
- Indoor and outdoor painting
- Chemical washing
- Polish existing granite flooring
- Revarnish + lacquer for all doors, pacquet floor + skirting
- Paint all doors to dark walnut
- Replace all existing switch cover, door bell, etc...to white designer switches
- Construct base for fridge and washing machine
- 1 wall colour for kitchen
- Labour to change kitchen sink
Total cost: Appro. $17, 000
Hmm...I hope I did not miss out anything...cos we did some additional works..
Saw your price for power point,
- 08 nos. single power point. $400
so that is $50 each, mine is $45 each
- Supply labour to install 2 toilet bowl , 2 wash basin , toilet accessories , taps & instant water heater. $350
Mine is change 2 toilet bowl + install all other toilet acc $180
U can view my blog for the progress of my reno, www.kohnlee.blogspot.com
