Renovation Quotation Seems Very Weird
Hi, i just get quotations from a contracter, and my mom actually unknowingly go pay the confirmation payment.
The quotation goes like this.
Demolish works $2600
hack and disposal of existing two toilet and kitchen floor tiles and wall tiles.
Masonry Works
Lay homogenous floor tiles kitchen $1500 $2.80/tile
lay water proofing membrane at kitchen area $250
Lay ceramic wall tiles $2600
Lay homogenous floor tiles Master toilet $500 $2.80/tile
Lay water proofing membrane at master toilet flooring $150
Lay ceramic wall for master toilet $1500
Lay homogenous floor tiles at common toilet $500
Lay water proofing membrane at common toilet flooring $150
Lay ceramic wall tiles at common toilet $1500
Touch up wall / floor / skirting $450
Build est:23'L kitchen base $600
Install rubbish hood at kitchen area $180
Carpentry Works
Build concrete stove 7'L x 32'HT with tiles $1330
Design & fabricate est 7'L kitchen cabinet in ABS trimming laminated door c/w Soft close swing door $840
i) design handles & cutlery tray
ii) Supply labour to install cooker hood & hob at kicthen cabinet
Design & fabricate 3.5'L top cabinet to box up kitchen cabinet piping and storage $630
Design & fabricate 3'L tall cabinet at kitchen area $750
Install soild-top surface at kitchen cabinet est: 7ft $560
Plumbing Work
Install stainless piping for kitchen and 2 toilets $680
Install Water heater for 2 toilet $200
Install toilet basin for 2 toilets $120
Install toilet bowl for 2 toilets $200
Install toilet assessories for both toilets $80
Install toilet bidet sprayer for 2 toilets $80
Install shower head for 2 toilets $100
Replace discharge stack at kitchen area $799
F.ceiling Work and Painting work
plastering ceiling at one kitchen and 2 toilets $560
Paint ceiling kitchen and 2 toilets $600
Insyall 9'L X 4'HT aluminum window grills at kitchen area $300
Glass door and wooden door
tempier sliding glass door at master bedroom $780
temper glass sliding door 3'L x 7'HT at kitchen entrance (half sandblast) 780
Aluminum bi-folded door with acrylic frame $240
Miscellaneous/ General service works
chemical to clean up whole unit $300
General cleaning upon completion
Disposal of debris to NEA designated dumping site $450
Uplifting all building materials from void deck to renovating site $200
Lay protectuon Cover whole unit flooring $200
Total $21,749
Above is teh cost for renovating both toilets and kithen.
Personally i believe this quotation is kinda expensive especially the miscellaneous area. SHould there even actually have such cost?
I believe most contractors dont have?
Touching up of unsatisfied area are also in the miscellaneous cost, shouldnt these be included in renovating project, why should consumer be paying this. Instead to my knowledge, consumer can opt not to acknowledge if work done is not satisfied.
I need alot of help, please advice.
May email me at swainchua@yahoo.com.sg or drop me a message here.
Thank you.
Thank you.
Its all depend on the miscellaneous area. And all contractor have it, even ID also have it. And I'm not sure what is actually the touch up for? U got wall tiles, floor tiles no skirting...so where is this cost for....hmmm....
Hi there.
Maybe you would like to get them to include the dismantling of toilet items in the hacking and seek a direct plumber help on the following installation?
It cost me around $80 to dismantle items in 2 toilets.
Plumbing Work
Install stainless piping for kitchen and 2 toilets $680 - ?
Install Water heater for 2 toilet $200 - direct plumber est S$70 for 2 toilet
Install toilet basin for 2 toilets $120 - direct plumber est S$80 for 2 toilet
Install toilet bowl for 2 toilets $200 - direct plumber est S$120 for 2 toilet
Install toilet bidet sprayer for 2 toilets $80 - direct plumber est S$60 for 2 toliet
Install shower head for 2 toilets $100 - direct plumber est S$80 for 2 toliet
Replace discharge stack at kitchen area $799 - ?
