Reno Quotes $75481.88- Please Advise!
Hi all, Being looking through the forum and found the advice here very the good.
I am doing a renovation soon and was quote the price $75481.88
Kindly advice?
A Preliminaries INCLUDED
1 Consultation and Design 1.00 LS
2 Hand-sketch drawings 1.00 LS
3 Material choosing and color coordination 1.00 LS
4 Application to the related authorities 1.00 LS
5 Project management and supervising 1.00 LS
B Dismantle/Demolition and Disposal $ 3,980.00
1 Dismantle all the fixed joinery work 1.00 LS
2 Dismantle all the existing false ceiling 1.00 LS
3 Dismantle the existing windows 1.00 LS
4 Dismantle the existing window grills 1.00 LS
5 Dismantle the existing gate 1.00 LS
6 Dismantle the existing main door and frame 1.00 LS
7 Dismantle the existing bed room and toilets doors and frames 1.00 LS
8 Dismantle the existing light fittings, light points and power points wiring 1.00 LS
9 Dismantle the existing 3 toilets sanitary wares and accessories 1.00 LS
10 Dismantle the existing balcony awning 1.00 LS
11 Hack the existing 3 toilets wall and floor tile 1.00 LS
12 Hack the existing utility area floor tile 1.00 LS
13 Create opening from bed room 2 to WC 2 1.00 LS
14 Hack the existing bath 1 corner wall 1.00 LS
15 Create opening from bed rrom 2 to bedroom 3 1.00 LS
16 Disposal 1.00LS
C Masonry Work $ 2,038.00
1 Brick wall to create back the kitchen area 108.00 sqf
2 Brick wall to seal-up the existing WC 1 door and create new opening from bed room 332.00 sqf
3 Brick wall to create back WC 1 area 56.00 sqf
4 Brick wall to seal-up the existing WC 2 door and create new opening from bed room 240.00 sqf
5 Touch up the new opening from bed room 2 to bed room 3 1.00 LS
D Tiling Work and Water proof $ 10,783.88
1 Supply and lay new floor tile with skirting to utility area 108.00 sqf
2 Supply and apply water proof to the WC 3 floor 36.00 sqf
3 Supply and lay new floor tile to the WC 3 floor 36.00 sqf
4 Supply and apply water proof up to 1200mm height to the WC 3 wall 120.00 sqf
5 Supply and lay new wall tiles to WC 3 192.00 sqf
6 Supply and apply water proof to the WC 2 floor 125.00 sqf
7 Supply and lay new floor tile to the WC 2 floor 125.00 sqf
8 Supply and apply water proof up to 1200mm height to the WC 2 wall 252.50 sqf
9 Supply and lay new wall tiles to WC 2 404.00 sqf
10 Supply and apply water proof to the WC 1 floor 48.00 sqf
11 Supply and lay new floor tile to the WC 1 floor 48.00 sqf
12 Supply and apply water proof up to 1200mm height to the WC 1 wall 160.00 sqf
13 Supply and lay new wall tiles to WC 1 256.00 sqf
14 Supply and lay new wall tile to kitchen 33.75 sqf
E Plumbing Work $ 2,510.00
1 Supply and install new incoming water stainless steel pipe 1.00 LS
2 Supply and install kitchen sink water inlet and outlet 1.00 no
3 Supply and install washing machine water inlet outlet pipe 1.00 no
4 Supply and install WC 3 water inlet outlet for toilet bowl, basin, and jet spray 1.00 set
5 Supply and install WC 2 water inlet outlet for toilet bowl, basin, jet spray and bath tub 1.00 set
6 Supply and install WC 1 water inlet outlet for toilet bowl, basin, and jet spray 1.00 set
F Sanitary Wares $ 2,895.00
1 Supply and install kitchen sink 1.00 no
2 Supply and install kitchen sink tap 1.00 no
3 Supply and install washing machine double outlet tap 1.00 no
4 Supply and install WC 3 toilet bowl 1.00 no
5 Supply and install WC 3 jet spray tap 1.00 no
6 Supply and install WC 3 basin 1.00 no
7 Supply and install WC 3 basin tap 1.00 no
8 Supply and install WC 3 toilet accessories 1.00 set
9 Supply and install WC 1 toilet bowl 1.00 no
10 Supply and install WC 1 jet spray tap 1.00 no
11 Supply and install WC 1 basin 1.00 no
12 Supply and install WC 1 basin tap 1.00 no
13 Supply and install WC 1 toilet accessories 1.00 set
14 Supply and install WC 2 toilet bowl 1.00 no
15 Supply and install WC 2 jet spray tap 1.00 no
16 Supply and install WC 2 basin 2.00 no
17 Supply and install WC 2 basin tap 2.00 no
18 Supply and install WC 2 toilet accessories 1.00 set
G Electrical Work $ 5,077.00
Supply material and provide new wiring for all lights and power points
1 Light point 24.00 no
2 1x13A power point 3.00 no
3 2x13A power point 20.00 no
4 15A power point - heater 3.00 no
5 20A power point - aircon 2.00 no
6 1 gang switch 3.00 no
7 2 gang switch 7.00 no
8 3 gang switch 5.00 no
9 1 gang 2 way switch 2.00 no
10 2 gang 2 way switch 1.00 no
12 Dimmer switch 3.00 no
13 Light sensor 1.00 no
14 Bell point and switch 1.00 no
15 TV/SCV point 5.00 no
16 Telephone point 5.00 no
17 New DB box 1.00 no
H Other Electrical Items $ 9,438.00
1 Supply and install storage heater 1.00 unit
2 Supply and install instant heater 2.00 unit
3 Supply and install bell unit 1.00 unit
4 Supply and install system 3 inverter air-con 1.00 set
5 Supply and install system 2 inverter air-con 1.00 set
6 Main entrance down light 2.00 no
7 Utility areas ceiling light 1.00 no
8 Living, dining and study ceiling light 4.00 no
9 Kitchen ceiling light 2.00 no
10 Toilet ceiling light 3.00 no
11 Kitchen ceiling wall light 3.00 no
12 Staircase light 1.00 no
13 Corridor light 2.00 no
14 Bed room ceiling light 4.00 no
15 Bed room down light 3.00 no
16 Toilet basin light 3.00 no
J Gypsum Board Work $ 1,800.00
1 L-box for ceiling 1.00 LS
2 Box-up some exposed pipe 1.00 LS
3 False ceiling at main entrance 1.00 LS
4 Partition at bed room 1 1.00 LS
K Gate, Door Frame, Door, Window and Window Grill $ 5,810.00
1 Supply and install galvanised wrought iron gate 1.00 unit
2 Supply and install main door and frame 1.00 unit
3 Supply and install rooms doors and frames 3.00 unit
4 Supply and install WC doors and frames 3.00 unit
5 Supply and install aluminium sliding and casement windows 7.00 set
6 Supply and install aluminium sliding window grill 7.00 set
7 Supply and install WC reinforced nako windows 3.00 unit
L Carpentry/Joinery Work $ 28,670.00
Solid plywood, white PVC inner cabinet, laminate finish, heavy duty hinges, heavy duty drawer runner and ABS rimming around drawer front and cabinet doors
1 Shoe cabinet - full height 1.00 unit
2 Utility area seater cum low storage 2.00 unit
3 TV cabinet 1.00 unit
4 U-shape top and bottom kitchen cabinet complete with solid surface work top and incorporated iron table 1.00 set
5 Top and bottom study table 2.00 unit
6 Full height book cabinet 2.00 unit
7 Seater cum storage 1.00 unit
8 Bed room 3 plat form and low storage cabinet 1.00 unit
9 Bed room 2 full height wardrobe 1.00 unit
10 Bed room 2 full height storage cabinet 1.00 unit
11 Bed room 2 dressing table 1.00 unit
12 WC 2 basin cabinet with mirror 1.00 unit
13 Bed room 1 full height wardrobe A 1.00 unit
14 Bed room 1 study table A 1.00 unit
15 Bed rooom 1 wardrobe B 1.00 unit
16 Bed room 1 study table B 1.00 unit
M Painting Work $ 2,160.00
1 Supply material and apply emulsion paint for the whole house ceiling 1.00 LS
2 Supply material and apply emulsion paint for the whole house exposed wall 1.00 LS
N Clearing and Cleaning $ 320.00
1 Daily clearing work 1.00 LS
2 Daily cleaning work 1.00 LS
3 Final washing and cleaning work after the renovation
1.00 LS
Total = $ 75,481.88
looks very ex... maybe jaskel can help on this...
maybe u can look for those sanitary ware urself.. 2.8k.... all grohe ?
1) Electricial work 14k?
2) Capenrtry 28k?
3) Painting 2.1k?
4) Pumbing 2.5k?
Crazy...
Which ID huh? Your items and my items are 95% same, overhual reno but price I'm like half of urs.
Edited by sunnytan31
Sorry for missing out the information. I very noob in this that why not sure what to put in
I just brought a HDB EM unit in yishun
It a overhaul renovation
Got 3 room and 2 toilet upstairs and 1 toilet downstairs.
Basically downstair tearing down almost all the so call room to make space bigger
Most of the item include the part maybe that why it expensive? such as aircon unit, light ,heater oven and so on....
anything else i need to put up?
It is hard to say if the quote is reasonable. Are you able to tell us the size of the carpentry work? It is easier to tell whether the quote is high or low by looking at the cost for every foot of cabinet constructed (per foot run). Yes, I notice that the quote includes supplying the lights, sanitary wares and electrical applicances. I think it might be cheaper to get these items yourself. Maybe you can ask your ID to give a breakdown of the cost of these items and go the respective shops to make a comparison.
Kindly advice?
16 Disposal 1.00LS
1.00 LS
Total = $ 75,481.88
Maybe you want to find out the dimesion of the carpentry works... It is very vague. List down as much as possible. As for toiletry and accesories... maybe you would want to consider getting yourself. They did not state down what are designs/brands of the accessories. I find that the quotation is really simplified... does not tell you with the type of of materials going to be used: example: paint, WC, basin, carpentry size and etc. Electrical work is quote ex...
Ha! Then $70k reno is possible. 2 storey hse, layman calculation is normal 4rm reno x 2, somemore u totally outsource all job to ur ID, include purchase for items.
not trying to put in any urgements here. but here how i c it, breaking it down part by part.
and, u must be rich, did u mention all these to ur ID or ur ID propose it to u? its realli lots of works, super costly! can do a bungalow liao haha...
1 Consultation and Design 1.00 LS - FOC
2 Hand-sketch drawings 1.00 LS - FOC
3 Material choosing and color coordination 1.00 LS -FOC
4 Application to the related authorities 1.00 LS - FOC
5 Project management and supervising 1.00 LS - FOC
B Dismantle/Demolition and Disposal $ 3,980.00 - looks like expensive. but depends on size.
1 Dismantle all the fixed joinery work 1.00 LS - Cant tell, dono dismantle where
2 Dismantle all the existing false ceiling 1.00 LS - depends on size, but shouldnt be expensive
3 Dismantle the existing windows 1.00 LS - FOC if u are doing up new ones
4 Dismantle the existing window grills 1.00 LS - FOC if u are doing up new ones
5 Dismantle the existing gate 1.00 LS - FOC if u are doing up new ones
6 Dismantle the existing main door and frame 1.00 LS - FOC if u are doing up new ones
7 Dismantle the existing bed rooom and toilets doors and frames 1.00 LS - FOC if u are doing up new ones
8 Dismantle the existing light fittings, light points and power points wiring 1.00 LS - so many to dismantle? cannot jus relay meh?
9 Dismantle the existing 3 toilets sanitary wares and accessories 1.00 LS - - FOC if u are doing up new floor & wall tiles, mean hw to hack floor & wall tiles if they didnt dismantle all the sanitary wares
10 Dismantle the existing balcony awning 1.00 LS - not sure, depends on size
11 Hack the existing 3 toilets wall and floor tile 1.00 LS - ok, standard
12 Hack the existing utility area floor tile 1.00 LS - ok, standard
13 Create opening from bed room 2 to WC 2 1.00 LS - near door way? hmmm not so expensive
14 Hack the existing bath 1 corner wall 1.00 LS - depends hw long is the wall, not very expensive also
15 Create opening from bed rrom 2 to bedroom 3 1.00 LS - ok la, not so expensive
16 Disposal 1.00LS - FOC~
C Masonry Work $ 2,038.00 - errr~ doesnt look like tat price.
D Tiling Work and Water proof $ 10,783.88 - looks expensive, but subject to wat kind of price of tiles they let u to choose up to.
4 Supply and apply water proof up to 1200mm height to the WC 3 wall 120.00 sqf - errr why wall need water proofing?
8 Supply and apply water proof up to 1200mm height to the WC 2 wall 252.50 sqf - wall water proof?
E Plumbing Work $ 2,510.00 - o.O ncie one~
F Sanitary Wares $ 2,895.00 - supply & install, supply of labour or the equipments?
G Electrical Work $ 5,077.00 - oooooo~ but looks quite ok la..cos looks like u got alot to do hahah
H Other Electrical Items $ 9,438.00 - stunned!!! so many electric works? u must be rich
J Gypsum Board Work $ 1,800.00 - ok la, somewhere near there
K Gate, Door Frame, Door, Window and Window Grill $ 5,810.00 - no comments, haha
L Carpentry/Joinery Work $ 28,670.00 - dono size no comments. but, $28.6k can do up fully a 3 or 4 room flat liao.
M Painting Work $ 2,160.00 - hmm abit ex la. but double story, consider ok la...
N Clearing and Cleaning $ 320.00 - cheap!!!
1.00 LS
Total = $ 75,481.88 - i can do up a 3 story bungalow liao..
Before making comments like that, have you ever thought about the type of materials and equipment used. It looks like the quote includes equipment, which bumps up the cost. $75000, may or may not finish a bungalow depending on how much work you are looking at. If you were really fitting out a bungalow decently, you would be looking at $100,000 to $150,000. Have you even lived in a bungalow! There are 4rm or 5rm resale flats done for 70k and above.
1.00 LS
Edited by loonsy
loonsy dude. look clearly on wat i comment be4 u comment back.
Let me help u to open ur eyes.
i did mention abt size materials n equipments. so did u live in a bungalow and reno a bungalow with ur own money be4?
Kindly advice?
16 Disposal 1.00LS
1.00 LS
Total = $ 75,481.88
Hi Robin,
after taking a closer look at the amount of carpentry work you are doing, I actually think that the quote is quite low, especially your ID will also be supplying air-con, lights, sanitary wares etc which will cost more than $7k. My reno cost + the above 3 items also add up to about $76k. But of course the comparison is only reliable if I know the dimensions of your carpentry works.
  • 4 weeks later...
Hi Robin,
mine is also an EM overhaul but final quote stands at 84.5k. so i guess it's e norm for an overhaul job
$80k is average, $100-$150 is high end.
