Hall Pillar Ideas - Plz Suggest
Hi All,
We just bought a flat and want to demolish the wall dividing the hall but not sure if we will get the permit from HDB to do so due to pillar / beam. Hence, if the permit is not approved we decided to demolish the wall but keep the pillar.. Any ideas on how to make this look good?
Floor plan - http://img72.imageshack.us/img72/7291/hdbm.jpg
you're referring to the pillar located at the store or the study room?
On the study room.
On the study room.
for any hacking of wall need to get HDB approval..
go your ground floor at the same area see if there is any pillar lo. if at the same spot the pillar is there most prob you cannot hack away.
but by the looks of it, you should not have any issues hacking that away.
spots that cannot be hack are all those in black and those surrounding the house la..
  • 3 weeks later...
Didn't get the permit to demolish the pillar.. Any ideas on how to make pillar more appealing with the decor? Pls help..
Here are two ideas,
1. Make it into a statement. Perhaps you might like to thicken the pillar a bit, and paint it in an outstanding colour, or clad it in a material like wood veneer.
Over here, the stairs are done in such a manner that they become a statement piece in the house.
2. Hide it.
I have a feeling that behind the picture on the middle section of the wall is a pillar. You could extend the pillar a little such that it becomes a narrow wall, which you can use to hang pictures etc.
Images from Home & Decor
From floorplan, no problem to hack away the 2 walls which make up the study room, no pillar or beam at the centre. You are referring to the pillar near store room?. This pillar on left after entrance? It is well located ! It is the "eastern green dragon" in term of FS which has the "stabilising" function.
The folyer is rather short with big "throat".
Morning sun from 2300mm(10ft) windows, orientation correct?. You can't put TV set against wall of study room, because of rm 2 & rm 3 = sofa no backing. Sofa best to put against wall, but.....quite odd.... may be put up some wooden pillars as divider somewhere in the hall.....
The 2500mm (7.6ft) may be can put a 1.6/1.8 meter long dinning table with a mirror on the wall, may need to extend the pillar slighly longer towards the hall. Put photo frame or pictures...
Edited by bepgof
Thanks Gakuseisean.. Actually our plan is very similar to the second picture you posted.. Will convey this to our ID.
@ bepgof - Here is the url of floor plan again.. The pillar in focus is highlighted in red.
http://img17.imageshack.us/img17/9547/50711755.jpg
IC, thanks.
Edited by bepgof
