Where To Buy Gate Lock That Is Stuck To Gate
to open the lock, there is this metal horizontal piece that slides out so that you can open the gate.
its available in most hardware stores. try homefix
Thanks.
Is it something easy to fix myself or do I need to call in a locksmith?
Thanks.
can diy. i believe the locks comes with the allen key to install
Hi, you can get it at any hardware shops or selfix or DIY shops. It comes with instructions manual and can be fixed on your own. Very easy and a lady llike me can do it without any fuss...... I bought the brand duro and have been using it for years.
er, if after long time say few yrs being stuck, u wana remove, will it be hard cause it's like
tight fit & will it like scrape off yr gate's paint/coating? why issit better than those normal locks which u can
physically remove other than convenience? :dribble:
its actually a 2 piece lock held together by 2 screws. just remove the screws and the lock should come apart with minimum damage to your gate.
this kind of lock easier to manage with 1 hand in cases where u are carrying shopping bags. normal conventional locks needs 2 hands to operate as u need to hold on the the lock
  • 10 months later...
For more convenience, this is my lock & key set for main grille & door; i.e. door & gate using the same piece of KEY!!
One Key System
  • 2 months later...
