Is This Quotation Reasonable?
Demolition Works
- Dismantle existing s/s sink @ service balcony. $25
- To remove existing wood skirting @ master bedroom. $80
Masonry Works
- To built cement concrete base with selected tile @ new washing machine area and cabinet area. $350
Carpet Floor Works
- Supply labor and material to overlay floor tiles in selected Carpet @ Master bedroom and bedroom 2 $1,755
Aluminum Window/ Grille /Doors
- To install top hung sliding wooden frame door w/ clear glass @ master bedroom. 4 $2,000
- To install aluminium frame with clear glass sliding door / top and bottom track @ master bedroom. 4 $1,300
Electrical Works estimate
- Lay new lighting point 8 $396
- installation of light
- 1x 13A power point
- 2 x 13A power point
- Replace new switches
*Note: Lighting Fitting to be provided by client.
Wooden Doors/ Veneer door works Framing
- Relaminate of existing door @ Master Bedroom (2 doors) $720
Carpentry Works
Master Bedroom
- To install Bed head Cushion padding in selected fabric finish on existing bed head panel. 1 $900
- Relaminate of existing 2 x bed side table for master bed. 2 $250
- Design & fabricate study table w/ glass top surface in selected laminate finish. (4ft length) 1 $720
- Design & fabricate dresser unit w/ stool in selected laminate finish w/ mirror panel. (4ft length) $984
- To install raise platform w/ plywood finish. 1 $870
Kicthen
- Design & fabricate storage cabinet to conceal piping in selected laminate finish @ Service Balcony. $720
Living Room
- Design & fabricate Altar shelf w/ feature panel in spray paint finish. 1 $1,500
- To install laminated wooden ledge for display column @ 2 sides of the room 4 $288
Cleaning Works
Supply labor to clean up master bedroom after renovation. 1 $100
I know these are not standard renovation works order.
The ID is my fren's company. so he claims that what he is giving me is already very cheap.
Therefore I din not even go around asking for other quotations or designs from other IDs
However, my frens all told me that I should do price comparison before committing.
I will still let my fren do the job no matter what is the outcome here in the forums.
But at least I know whether i got kena getok or not.
Edited by knownothing
Hmm..
since you already decide u will let ur friend do the job regardless what.
Why you want to know whether u got kenna crop or not.
If ur friend price is a very friendly price, you will feel happy. That's my friend.
If tio crop, how? Still give the job to ur friend.
If give to your friend, you had a needle in ur heart. U crop me. U crop me.
Like that song mah?
No la, I already promised him I will give him the job, and once promise is out, I cant take it back.
WhaT I wanna know is whether he is a worthy fren or not. If he getok me, at least I know I have one less fren.
by reading on the description without knowing the detailing, i think you friend did not gotok you,
price are quite reasonable as a friend :)
