Please Help Me To Take A Look At The Quoation
I know nuts about renovation. This forum indeed is a 'great help' to me.
I just gotten a quote from the ID.
Appreciate you guy to to please help me to take a look whether is it a reasonable quote.
Appreciate all your feedback and comments and what i should take note and look out for. Thanks!
< Quote>
Re : Renovation works at above mentioned address
Amount
Professional Services
1 Design & site co-ordination
2 Space planning layout plan
3 Perspective drawings on all carpentry works
4 Warranty of workmanship & after sales services for 12 months
5 Arrangement for PUB gas pipe installation
6 Consultation on selection of lights, furnitures & accessories
Demolition Works
1 Hack existing flooring @ kitchen $450.00
2 Hack existing flooring @ living & dining $880.00
3 Hack partial wall between living and kitchen $550.00
4 Hack existing flooring & wall tiles @common bathroom $550.00
5 Hack existing wall tiles @ kitchen area $660.00
6 Hack existing flooring & wall tiles @ master Bathroom $550.00
7 Hack existing flooring & skirting @ 03 bedrooms $600.00
8 Dismantle existing kitchen cabinet, wardrobe storage cabinet if any $450.00
9 Dismantle all bathroom sanitary @ 02 nos. bathrooms $100.00
10 Dismantle all doors , door frames , sliding doors etc.(as per owner's request) $100.00
11 Dismantle all cornices , false ceiling & L-Box (as per owner's request ) $500.00
12 Distmantle rubbish chute FOC
Living / Dining & Bedroom
1 Create new tampered glass partition btween living & kitchen $1,500.00
2 Supply & lay new cement screeding flooring @ living $950.00
3 Supply & lay new berry floor hydro plus laminate @ living $4,225.00
4 To supply & do cement screeding to two bedrooms $380.00
5 To supply & lay new berry floor hydro plus laminate @ 03 bedrooms $3,079.00
6 Made good at affected area on hacking wall $450.00
Kitchen Area
1 Supply & apply waterproofing membrane with upturn of 300mm $300.00
2 Supply & lay heavy duty ceramic / homogeneous floor tiles c/w cement screeding work $1,300.00
3 Supply & lay heavy duty ceramic / homogeneous wall tiles up to ceiling height (expose area only)$2,850.00
4 Supply & construct fridge, washing machine base with tiles finish $150.00
5 Supply & construct cement mortar kitchen cabinet base $150.00
Master Bathroom
1 Supply & apply waterproofing membrane with upturn of 300mm $150.00
2 Supply & lay heavy duty ceramic / homogeneous floor tiles c/w cement screeding work $450.00
3 Supply & lay heavy duty ceramic / homogeneous wall tiles up to ceiling height $1,450.00
Common Bathroom
Plumbing Works
1 Supply & run new stainless steel piping to whole unit $650.00
2 Supply & run PVC inlet / outlet piping for kitchen sink & washing machine including installation $220.00
3 Supply labour to install instant heater or storage heater $80.00
4 Supply labour to install WC, wash basin & kitchen sink $420.00
5 Supply labour to install bathroom accessories FOC
6 Box up sewage pipe $350.00
7 Supply labour to install hand spray point $60.00
8 Supply labour to install shower sets $80.00
Painting Works
1 Supply & apply 03 coats of NIPPON paint to all internal walls & ceilings (max. 5 colours) $1,450.00
2 Supply & apply ICI gloss paint to all water piping, gates, doors, door frames & sewage pipe $150.00
3 Supply & apply sealer coating to all new partition ceiling $220.00
4 Supply & apply easi plaster to plaster smooth wall areas for whole unit *upon request $2,500.00
Door Works
1 Supply & install 02 nos. of aluminium frame bi-fold door c/w acrlic panel @ 02 bathrooms $440.00
2 Supply & install 03 nos. new designer timber doors $900.00
Tampered Glass Works
1 Supply & install col. Glass backing between kitchen cabinet $1,500.00
2 Supply & install 02 sets shower sceen $1,400.00
Design Ceiling Works
1 Design and construct new false ceiling light box cum cove lighting @ living $900.00
2 Design and construct new false ceiling light box cum cove lighting @ dining $900.00
3 Supply & install design false ceiling @ master room $550.00
4 Supply & install design false ceiling @02 bedrooms $1,000.00
Miscellaneous
1 Chemical wash upon completion of wet works $250.00
2 Provide & lay protection sheet $220.00
3 Provide HDB debris container from relevant department & disposal off site $800.00
4 Haulage Of sand and material $680.00
5 Supply & install 01 set wrought iron main gate to entrance $550.00
6 To supply & install new rubbish chute $220.00
7 To supply & install new louvre windows at toilet $480.00
Custom Made Build-in Furniture
Kitchen Area
1 Design & fabricate top / bottom kitchen cabinet in laminate finish c/w swing door &
drawer * accessories supply by owner base on 36ft $4,400.00
2 Supply & install new design glass door @ kitchen entrance $1,200.00
3 Supply & install kitchen solid surface work top with intergrated sink base on 15ft $1,800.00
Wash Area
1 Supply & lay heavy duty ceramic / homogeneous floor tiles and wall tiles $1,200.00
Grand Total : $50,394.00
We thank you for the opportunity to the above quote and look forward to be of service to you. Should you
require any other further information, please do not hesitate to contact the undersigned. Thank you.
TERMS & CONDITIONS
Payment Terms
30% of Contract Sum upon Signing & Confirmation
40% of Contract Sum upon Commencement of works
25% of Contract Sum upon Commencement of Carpentry works at Factory
05% of Contract Sum upon Completion
CONFIRMED BY:
____________________________
NAME :
NRIC :
< Quote>
Amount
Demolition Works
Kitchen Area
Master Bathroom
Common Bathroom
Plumbing Works
Painting Works
Door Works
Miscellaneous
Kitchen Area
Wash Area
TERMS & CONDITIONS
Payment Terms
CONFIRMED BY:
NAME :
NRIC :
If ID can provide you fantastic design & service, then is worth paying for :yamseng:
another point you can negotiate for is better payment terms:
I'm currently renovating my place. my terms are:
10% upon signing
10% after hacking and selection of materials
25% after 25% of work is done
25% after 50% of work is done
15% after 75% of work is done
15% after completion and handing over.
My contractor is comfortable with such payment terms with us. We told him we don't feel comfortable paying before work is done and we heard alot of horror stories in the industry. So he's has so far kept his side of the bargain by performing well so we might pay faster to encourage him.
Very important is the final payment after handing over it has to be minimum 10%, if can get more.. better. 5% usually is no power. If there's any disputes, contractor/ID is prepared to walk away and dun earn the last 5% as their margin is already 15-20% in some cases. If you hold more than 10%, you can be sure he'll do his best to do a good handing over.
This forum has too many threads of homeowners paying too much in advance and even pay complete before handover. When you control the money flow, you can control the work process and satisfaction. Renovation is not cheap, do your homework, check.
Lastly, one look at your quote and I know it's expensive by 10-15% liao. Go read up in this forum ,there's alot of discussion on market prices. BUT you must make sure you are comparing apples to apples. Materials used can make alot of diff to the price. So do compare correctly.
Enjoy!
All the prices are marked up around 10% for you to negotiate it down if you really want to engage this ID.
By the way, there are few items I noticed the quoted price is far too high than average. You better search around.
Is your living room very huge? Maybe you want to check the psf price for the flooring because I wondering why your living room is bigger than total 3 bedrooms. I am not very sure too because I don't intend to do laminate flooring but perhaps you want to double check on this.
For painting, better check which type of Nippon paint will be provided unless you are not particular on this. Some contractor will want you to top up $$ if you want better range of paint.
Also check with your ID which brand of solid kitchen top will be provided because $120pfr shld get a good brand I think.
30% of Contract Sum upon Signing & Confirmation/40% of Contract Sum upon Commencement of works
This means 70% $$ will be paid once work start. Don't you think it sounds risky to you? Anything you find not to your requirement on site during the renovation may not be fully rectified then.
FYI
4. Cost of clearing of debris and haulage
**** As per conversation with HDB council, the standard cost for clearing of debris and haulage is always at the cost of $215 inclusive of GST. Do not be surprised when contractor quote you more than $500 and do not get convinced by them when they told you the reason why it is so expensive. Some contractor will tends to tell you that they have rented a lorry to collect debris, this is not true. The lorry is provided by HDB who will do the clearing up. The contractor only needs to pay them $215 and everything will be done properly. Reason: HDB pay outsiders to do the clearing and this is liaise with the contractor and the HDB third party, when only a single receipt will be given. Best is to check with your HDB branch office. HDB bay contractors will tends to quote more in their hauluge fees, pls take note.
how big is your house???
some items are expensive..
- dun think the glass screens are so big right?
these 2 also ex...mine is EM is about this price....
- your hacking quoted is very expensive! at $5390? maybe you want to check around with others.
- Your flooring seems expensive. I am not sure of the size of your living room. I know Berry flooring also not cheap too.
- what kind of timber doors are they giving you? veneer?? comes with lockset? mine is at $270 per set for veneer doors and comes with lockset.
- def overcharge on this!!!
Wash Area
- they are charging you at $120 per foot run for solid surface top which is expensive. Usually contractor price is $80 per foot run. If you go direct to granite supplier, you can also get $80 per foot run for Indian black granite.
Payment Terms
- Payment terms is def not to your favour!
Arowana! Thanks men!!! I will definitely neg on the payment terms once we confirmed on the renovation Co.
Whisper: thanks!!
Jezlaw: Thanks for the info!! Good lesson learnt.
Joyousanline: yes, is exp. I almost fall off from my chair.
The 5 room flat to me not very big. About 114-118sqm.
I dunno how to attach the floor plan.. :unsure:
FYI
I just check with 1 contractor. He told me $215 is for new flat without doing any hacking and retiling work ? And he said resale flat at least $600 :unsure:
Hmm..i will call up town council tom & check.
I'm using a contractor and mine is a resale unit and we are going to hack all the floor and wall tiles includes the toilets plus a door sized wall. And it is $300, that is for the haulage service and clear all debris off site. Maybe you want to check with him again..
$300!! cheap !!! Can email your quotation for me to compare ? Heeee
I called up town council & also HDB office, for resale flat, it all arrange by the contractor. So HDB or town council wont't arrange any container and haulage for clearing the debris except for NEW FLAT.
Wash Area
Payment Terms
Hello joyousonline, can you please share your contractor's contact??? thanks so much!!! =D
eh, i guess some of my quote may not be suitable for you. As we have different size area of things to be done, and different things and material to do. Things like haulage service and debris can be comparable, and some other basic items, such as plumbing work, paint work, rewiring work, etc.
Just to note, my quote is from a contractor not an ID. If the quote is from ID, of course it will be roughly 10% more then contractor. Reason is that, ID will look for contractors to get the jobs done. So, IDs will get their cut of comm. They can't possibly do work for you for free. So you can't expect the ID to charge the same price as contractor. And if hiring contractor, you should know what you want.
Will PM you in a while. :)
have PM you his contact!
Thanks!! U r right! Maybe I should re-consider contractor instead of ID.
