Advise On Renovation Quote
Hi all, please help me see whether this renovation quote is reasonable, coz am new to renovation. Thanks in advance! =)
DEMOLITION WORKS
To supply labour & hack new opening at common toilet - $350
MISCELLANEOUS WORKS
To supply & paint of wall & ceiling for whole house include all expose piping (original paint) - $1,050
To supply & paint existing door frame - $100
To haulage material to unit c/w debris disposal - $280
To supply labour for general cleaning whole house include acid cleaning for floor, wall & window - $200
PLUMBING WORKS
To supply labour to joint in/out let pipe for kitchen sink - $120
To supply & extended stainless steel pipe at kitchen sink & (s) yard - $200
To supply & run 01 hand spray point for master toilet - $20
To supply & run 01 hand spray point for common toilet - $20
To supply labour to install 01 no standard wash basin at master toilet c/w lever tap (cold water only) - $70
To supply labour to install 01 no standard wash basin at common toilet c/w lever tap (cold water only) - $70
To supply labour to install toilet accessories at master toilet - $35
To supply labour to install toilet accessories at common toilet - $35
To supply labour to install heater - $120
CEILING WORKS
To supply & install false ceiling **** with plaster board - $450
To supply & install L-box cornices at dining with plaster board - $450
To supply & install false ceiling at passage way with plaster board - $220
To supply & install false ceiling at foyer with plaster board - $180
To supply & install cove light holder at dining - $280
To supply & install false ceiling at master bedroom with plaster board - $350
To supply & cove light holder at master bedroom - $180
MASONRY WORKS
To supply & construct 50mm fridge base with tile finish - $120
To supply & construct 50mm washing machine base with tile finish - $120
To supply & construct 50mm cabinet base with tile skirting - $280
To supply & touch up & make good damage edge after hacking new opening at (s) yard with cement & tiles finish - $320
CARPENTRY WORKS ****
To supply & fabricate 7ft designed feature wall **** c/w laminate finish - $1,330
To supply & fabricate 7ft designed TV consol with laminate finish - $770
To supply & fabricate 11ft settee cum storage **** c/w laminate finish - $1,320
CARPENTRY WORKS AT FOYER
To supply & fabricate 8ft designed feature wall at foyer to cover household shelter c/w laminate finish - $1,520
CARPENTRY WORKS AT MASTER BEDROOM
To supply & install pull out mirror at wardrobe - $180
To supply & fabricate 7ft designed full high wardrobe c/w glass sliding door aluminium frame & laminate finish - $1,715
CARPENTRY WORKS AT ROOM 2
To supply & fabricate 6ft designed full high wardrobe c/w glass sliding door aluminium frame & laminate finish - $1,470
CARPENTRY WORKS AT ROOM 3
CARPENTRY WORKS AT KITCHEN
To supply & fabricate 24ft solid plywood kitchen cabinet c/w laminate finish, 2 glass door, 4 drawer, 1 cutlery tray & 1 stainless steel dish tray - $2,280
To supply & install 12ft solid surface work top with 3 inch profile - $780
To supply & install 04pairs Blum soft closing drawer track at kitchen - $320
To supply & install soft closing hinges at kitchen cabinet doors - $200
CARPENTRY WORKS AT MASTER TOILET
To supply & fabricate 3ft suspended vanity cabinet c/w glass door aluminium frame & laminate finish - $390
To supply & install 3ft solid surface top c/w 2 inch profile - $195
To supply & install 1 pc full mirror - $190
CARPENTRY WORKS AT COMMON TOILET
GLASS WORKS
To supply & install 10mm tick wall to wall tampered glass shower screen at master toilet c/w swing door - $320
TOTAL COSTS: $21,205
Looks cheap to me. ID or contractor? Can give me contact?
Hi SephLord, it is ID.
IC. 21k for ID is real cheap imo. My contractor quoted me 30k for his services.. :furious:
Hi SephLord, dun mind can tell me who is your contractor?
Sent u a pm. ;)
DEMOLITION WORKS
MISCELLANEOUS WORKS
PLUMBING WORKS
CEILING WORKS
MASONRY WORKS
GLASS WORKS
Price is fair but if they can provide high-quality job then is more worth :good:
its very cheap, i would say TOO CHEAP. Will the ID limit yr choice of laminates? i heard of very cheap carpentry, but they limit u ALOT of things. u want nicer, they ADD-ON...... Some laminate are REAL CHEAP. Anyway, best of luck.
Quality, another question.
One very important item missing- ELECTRICAL.
u might be ripped off in this area.
its called- pull long, patch short.
Edited by tapilia
If job done to your liking it's cheap. I spent more than 26k re-doing 2 toilets, kitchen cabinet, polish flooring and installed light fittings, painting whole flat and cleaning.
Hi tapilia, am not sure of the quality too, coz haven go & see their showroom.
Wah! $26K jus for 2 toilets & stuffs. We're on budget, so am trying not to do too much, jus the basics at least will do.
The quote is very fair. Try to find out more about the ID, see if he/she is experienced or not...cause new IDs usually don't dare to charge ex
Also, don't hurry up and sign because its cheap. Take your time to look around.
Btw, did you just copy paste from the quotation or you type it out yourself. Because this format is really very familiar, including the lack of electrical quotes.....care to pm me the contact? Maybe its a company I know...
Edited by renoseeker
No flooring done? 21k does not look real cheap if no flooring not inclusive.
Nope, no floorings done, coz we opt-in for the floorings & doors from hdb.
PM-ed u! =)
