Renovation Budget (Very New Home Owner)
Dear forumers,
I'v just got myself a resale unit. It's about 142 sqm.
I'm planning to overhaul the unit including:
1. To hack off some walls sections
2. Plastering + wall painting
3. Remove existing floor tiles and to re-lay new homo tiles
4. Remove existing wall tiles and new wall tiles up to ceiling
5. Re-lay new wirings + power points
6. Kitchen cabinets.
7. Sanitary fixtures
8. Electrical fixtures and fittings
9. Masterbedroom wardrobe
I have about S$50k budget. I'm wondering if it is sufficient and do i still have the luxury to engage an I.D. ? Thanks !
If hdb then the budget should be ok to get ID cum
Contractor. But if condo then will be a bit more difficult cos pricing for condo generally higher due to many hidden costs.
For 50k budget, an id will consider it a tight budget if u have above average expectations... a contractor should be able to do it at a ok range for the same expectation considering the mark down.
When it comes to renovation budget it is a limitless amount depending on your requirement n expectation... Happy renovating :thumbs up:
Dear forumers,
Agreed with Luciusteo
If you got mind set what your house gonna be. Ignore ID and go for a contractor.
You may save up some which u can use to invest more on TV or other item.
agreed but if id wish to do on contractor price i guess it will be the best
