Electrical Quotation For Re-Wiring (Hdb Resales)
was workmanship good? I think your price is very attractive as I mine charged me more but was recommended by ID. Could be profit split 2 ways hence more expensive for me.
Should have spotted this thread and save some money.
Cheers
  • 4 weeks later...
  • Replies 75
  • Views 64.7k
  • Hi, the TV point is SCV point. As for LAN point, my husband said he prefers lan point then wifi as the connection is more stable.
  • I get abit skeptical when i see newbies suddenly introducing electricians into this forum. Not to hijack your thread..but I will like to highlight and share again to all forumers that there has been c
  • Hi Janetan...while this forum is for sharing....I will like to stress again on 'responsible sharing'. Share it only if you have completed the work with your recommended Mr Pang. i'm sorry, but the gro
Hi Jane - Can you please PM me the contact of your electrician?
Thanks much in advance!
  • 3 weeks later...
Hello,
I've received a quote for my AMK 5 room home on re-wiring.
Light point > $30 x 28 = $840
Double 13 socket > $55 x 20 = $1100
Single 13 socket > $45 x 4 = $180
Water heater point (2 way) > $110
Air-con 20A ISO > $85
Hood & hob point > $55 x 2 = $110
Telephone point > $30 x 4 = $120
TV point > $60 x 4 = $240
Network point (Cat 6) > $90 x 5 = $450
New Distribution box (excluding main cable) > $350
Install downlight light > $7 x 24 = $168
Install hanging light > $10 x 4 = $40
Install ceiling fan > $30
Total > $3823
Discount > $323
Net > $3500
Got this contact from my colleague when i went to her house warming party. Saw the workmanship was okay and she was telling how good this contractor was. But was thinking if the quote is on the high side. Anyone could kindly rate this quote for me as this is the first time my husband and i does renovation. Many thanks.
Hi Jane,
I am very new to all these renovation work so please escuse me if this is a silly question. I was told by my ID that electrical re-wiring and lighting for my 2nd hand 1200sft hand place will cost easily over 5k due to the fact that workmanship cost is increasing. He also says that this includes running the wires through the walls that hacking. Hence the cost.
May I ask if your quote includes running the wires externally through trunking or concealed?
Hi, is it necessary to do pub testing if you change the Distribution box ? are there any HDB rules or application needed, if rewiring the whole unit?
Can someone pm or send here the contact of recommended electrician with reasonable price. Thanks a lot
Hi Jane, can PM me your electrician contact number? Thanx alot~
if engage a electrician contractor directly, is it common for them to charge transport fee?
  • 1 month later...
Hi June,
New to this forum.
Currently want to re-wiring my 3 room unit.
Care to pass me your electrical contractor Hp.
Thank you
well done...thread revived....beware of re-cycled scams from electricians self promoting themselves...or pretending to recommend 'good' electricians.
you've been warned!
  • 2 weeks later...
We did our reno in 2009. seems like prices have moved up quite a little.
Good way to reduce cost is to remove the false ceiling ( which will reduce the number of lighting points)
read the details on our blog
  • 1 month later...
Hi All,
Really, urgently need help here.For my new home a maisonette
Please advise if this quote is reasonable, Of course if I can would like to save some money
Thanks in advance
1Living
Downlights @ 6pcs @ $30 $ 180.00
Ceiling Lights @ 1pcs @$30 $ 30.00
Wall Light point @ 1pc @ $30 $ 30.00
13A x 2 @ 4pcs @ $55 $ 220.00
Tv point @ 1pc @ $90 $ 90.00
Telephone point @ 1 pc @ $50 $ 50.00
DB box @ 1 pcs @ $380 ( What is this ? ) $ 380.00
2Kitchen
Cooker hood switch 1pc $ 45.00
Ceiling Lights @ 3pcs @$30 $ 90.00
13A x 2 @ 3pcs @ $55 $ 165.00
Oven 1 @ 1pc @ $90 $ 90.00
Oven 2 @ 1pc @ $90 $ 90.00
13A @ 1pcs @ $50 $ 50.00
water heater point @ 1pc @ $90 $ 90.00
3Study Room
Ceiling fan with lights @ 1pcs @ $30 $ 30.00
13A x 2 @ 1pcs @ $55 $ 55.00
4TV Room
Downlights @ 8pcs @ $30 $ 240.00
Ceiling fan @ 1pcs @ $30 $ 30.00
13A @ 3pcs @ $50 $ 150.00
Install downlights point @ 14pcs @ $10 $ 140.00
Install Ceiling fan with lights @ 1pc @ $60 $ 60.00
Install Ceiling fan @ 1pc @ $50 $ 50.00
Install wall lights @ 1 pc @ $10 $ 10.00
Install Ceiling lights @ 8pcs @ $10 $ 80.00
1Room 1
Ceiling fan with lights @ 1pc @ $30 $ 30.00
2Room 2
13A @ 2pcs @ $50 $ 100.00
3Master Bedroom
Downlight point @ 9pc @ $30 $ 270.00
Aircon point @ 1pcs @ $100 $ 100.00
4Master , Comon Bathroom & Stairs
Ceiling light point @ 2 pcs @ $30 $ 60.00
Stairs downlight points @ 3pcs @ $30 $ 90.00
Water heater point @ 1pcs @ $100 $ 100.00
T5 point at staircase @ 2pcs @ $30 $ 60.00
2 way switch @ 1pcs @ $90 $ 90.00
5Installation
Ceiling fan with lights @ 2pcs @ $60 $ 60.00
Ceiling Fan @ 1 pc @ $50 $ 50.00
Ceiling lights @ 2pcs @ $10 $ 20.00
T5 lighting point @ 8pcs @ $10 $ 80.00
Install downlights point @ 10pcs @ $10 $ 100.00
Total Amount:- 4,325.00
7% GST:- $ 302.75
4,627.75
Edited by annasha03
Hi annasha03,
I can see your quotation is quite reasonable.
Can PM me your electrician's contact?
Any info/review on his past works?
Hi. Anyone care to share the contact of electrician quote which is reasonable?
