Spraying Of Black Colour Ceiling Fan Into White Colour
hi all,
i got a wrong color of ceiling fan, wish to get white instead of black. anyone have spray of black ceiling fan into white colour? what kind of spray is recommend? :sport-smiley-018:
TIA..
hi all,
TIA..
depends on the material. there is metal, plastic, wood paint... or could be a mix... But surely need a thick layer to change black to white....
What material is the fan ??
Some material have smooth finish which you will require a layer of (*Forgot what is it call) being applied to it before you spray it.
By the way from black to white, it is going to require big effort.
  • 3 weeks later...
I think you would have to sand it down, use primer 1st, then spray the white colour and finish it off with a lacquer/topcoat if preferred.
if the fan haven install just exchange easy. not only the blade spray, how about motor ??
  • 2 months later...
Personally I tried it out when I was younger (schooling) I spray painted the table fan blades and after a few months, the paint started peeling.
Not a very wonderful effect it sends to the room heheh :notti:
hi,
You can try Krylon spray paint I love it.. you might not even need to use priming.
http://www.performancecoatings.com.sg/
or you can get this brand Rust O luem spelling is something like that at DIY shops.
You would need to clean the surface of the fan first from dust before spraying. And it dries within a minute but for handling an hour.
All the best!!
recently just seen a new type of paint called plasti-dip at petrol stations. Not cheap $25/can but it seems to do the job without flaking!
  • 5 months later...
it's fanco fan. should be metal. ya think it's difficult.. sigh..
Maybe if you use spray paint will be okay
