April 13, 201511 yr Thinking of getting Mitsubishi starmex for my new house. May change to LGBetter think for this.Get LG should get inverter V = mirror panel model = more expansive than ME wow
April 14, 201511 yr Sorry just to check, are you refering to Starmex from Mitsubishi Electric or Mitsubishi Heavy Industry?
April 14, 201511 yr Sorry just to check, are you refering to Starmex from Mitsubishi Electric or Mitsubishi Heavy Industry?ME loh, what else!How many percent of household were used Starmex for thier home.Once got issue to be the faster new from here.Just believe who bought the unlucky unit.
April 15, 201511 yr I understand from Aircon technician that MHI is better than ME in term of qualityME loh, what else!How many percent of household were used Starmex for thier home.Once got issue to be the faster new from here.Just believe who bought the unlucky unit.
April 15, 201511 yr I understand from Aircon technician that MHI is better than ME in term of qualityMHI just a option to buy.Cause even the seller also told me don't get MHI at all.ME for quite satisfied.. Don't have cracking noise and any issue.
June 24, 201511 yr IF cant turn on with no power at all..anyway not related to aircon itself, for the power supply wiring can be failed also... anyway my MXY-GE24VA same problem also, after technician come and check for the wiring broken half way, just change the better wires as full brass, settled.Just changed and turn on like normal. Like ME much more easy to check on FCU, just open up the front cover and use test pen and check on the wires input located at right hand lower side, brown color must be have light on, IF the blue color wire also had light on, meant the wire already failed.IF you unknown it thing, later the aircon guy come over and they claims on others expansive parts to be change also.Hi kimsim,Are you saying that, just by replacing the Brown or Blue wire, the problem is cleared and FCU in full operation?
June 26, 201511 yr Hi kimsim,Are you saying that, just by replacing the Brown or Blue wire, the problem is cleared and FCU in full operation?IF 2 light blinking up down up down = indoor fan motor and PCB may replace
July 13, 201511 yr IF cant turn on with no power at all..anyway not related to aircon itself, for the power supply wiring can be failed also... anyway my MXY-GE24VA same problem also, after technician come and check for the wiring broken half way, just change the better wires as full brass, settled.Just changed and turn on like normal. Like ME much more easy to check on FCU, just open up the front cover and use test pen and check on the wires input located at right hand lower side, brown color must be have light on, IF the blue color wire also had light on, meant the wire already failed.IF you unknown it thing, later the aircon guy come over and they claims on others expansive parts to be change also.Hi kimsim, do they replace the wire all the way from compressor to fcu? Is it difficult job that requires any hacking?
July 14, 201511 yr Hi kimsim, do they replace the wire all the way from compressor to fcu? Is it difficult job that requires any hacking?Ya only the way
March 15, 201610 yr I have the same problem with my MSY-GE24VA. motor and PCB fault after less than a year.
April 19, 201610 yr Hi All: I just purchase new MIT Air-Cond( Star Mex MXY-3A28VA) at gain city , also have the problem..Indoor Unit auto shutdown and trigger Led Blinking 5 time per cycle ,then need to use remote controller to turn on again....anyone got this problem before ? I suspect the problem also happen to same series no MXY-xxxx...
April 24, 201610 yr Seems like users for GE24VA and GE26VA experience common issue. Any user with GE18VA encountering such problem?
April 25, 201610 yr Suggest also mention which company is the installer. Maybe cause by installer. My heater spoil within 1 month and the heater company came down and find that using lousy cable ( for lighting use wire cable). They change for me free. I bet installer may come apart as they are the one install wiring too.
April 27, 201610 yr On 19/4/2016 at 9:47 AM, kim5585784 said: Hi All: I just purchase new MIT Air-Cond( Star Mex MXY-3A28VA) at gain city , also have the problem..Indoor Unit auto shutdown and trigger Led Blinking 5 time per cycle ,then need to use remote controller to turn on again....anyone got this problem before ? I suspect the problem also happen to same series no MXY-xxxx... what tem are you having? if more than system 1, does other indoor unit got problem operating too? I faced such problem before with both my starmex and Panasonic..... indoor work a while got blower but not cold, then suddenly shut down, but other unit works ok.... both sets also electrical cable from indoor unit to outdoor unit got problem (rusty and broken somewhere)... change the cable, then no problem.... Usually aircon men will come and use a replacement wire to connect direct from your room indoor unit to the outdoor to test if the aircon working properly before they check the PCB and other component which are rarely giving problem.
April 27, 201610 yr On 25/4/2016 at 8:57 AM, clanbuster said: Suggest also mention which company is the installer. Maybe cause by installer. My heater spoil within 1 month and the heater company came down and find that using lousy cable ( for lighting use wire cable). They change for me free. I bet installer may come apart as they are the one install wiring too. u mean water heater using normal cable???
