How To Remove Black Stains On The Rubber Bit Of Shower Screen
Use tooth paste and brush, you can check out youtube on life hacks=)
  • 3 weeks later...
I recommend Magic clean stain & mold. You can get it from any supermarket. Cost around $5 for a small bottle. Cheap & effective.
Edited by gemini
  • 3 weeks later...
  • 2 years later...
  • 6 months later...
I have the same problem. I will try the white vinegar. It annoys me so much.
  • 2 years later...
On 10/15/2014 at 10:46 PM, lucky huat huat said:
How to remove the stains on those rubber bit of the glass panel?
This is actually caused by mould and yes you can clean it  but it will always come back so you have to kill the mould spores so that the mould does not return anymore forever
I used something called HCL89 to clean it, it managed to kill the mould spores and it has already been more than a year now and the mould has not returned to the rubber bits on my glass panel
I usually get the HCL89 from http://hcl89.byethost10.com or http://hcl89.atwebpages.com
Hope this helps you or someone else out :)
