Cost Of Parquet Flooring
Hi, can anyone share with me the pricing of parquet psf?
I'm considering to lay it in all my bedrooms.
Thanks in advance!
  • Replies 95
  • Views 111.3k
Hi Wayne,
I just did parquet flooring for my whole house. Three bedrooms and living/dining.
The breakdown:
Teak Parquet
12mm x 2" x 12"
835sft @ $2.30
= $1920
Teak skirting
11mm x 70mm
185 pfr @ $1.20
= $222
Wood glue @ 20kg
6 ctn @ $39.50
= $237.00
GST = $118.98
Installation:
To lay, grind & varnish
835 sft @ $1.20
= $1002
To install & varnish of skirting 70mm
185 pfr @ $0.40
= $74
Total cost: $3574.48
But after the guy came to measure the house, the total price dropped to $2808.28.
The workmanship is great and I love it! You can check out my link in my signature for pictures of my renovations.
Hau Hau Parquet & Wood Industries Pte Ltd
Showroom / Office: 302 Changi Road, Singapore 419780
• Tel: (65) 6 345 5061 / 6 345 5062 (Susan)
• Fax: (65) 6 345 1830
• Email: parquet@starhub.net.sg
www.hauhauparquet.com
Hope that helps!
Edited by writergal
Hi Wayne,
The breakdown:
Teak Parquet
12mm x 2" x 12"
835sft @ $2.30
= $1920
Teak skirting
11mm x 70mm
185 pfr @ $1.20
= $222
Wood glue @ 20kg
6 ctn @ $39.50
= $237.00
GST = $118.98
Installation:
835 sft @ $1.20
= $1002
185 pfr @ $0.40
= $74
Hope that helps!
hi writergal,
thanks for sharing!
base on your final price paid, your psf is around $3.40
i think its a pretty good price. :good:
my contractor quoted me double the price of yours. :unsure:
Hi Wayne,
I didn't ask my contractor to do it cause it was too expensive. Instead, I went directly to a teak manufacturer and they have their own recommended layers. So I cut out the middle man and paid direct prices.
I then liaised with my contractor with regards to the renovation process so that there wouldn't be any hassles.
Hope that helps you!
Hi Writergal,
no wonder you have such a good rate for you parquet.
cos you go directly to the supplier. the info you have provided
not only help me but to many other forumer as well.
really appreciate you help. :rolleyes:
  • 6 months later...
can you give me the contact for the parquet supplier?
thanks
  • 1 month later...
Hi, Wow, then doing real parquet is maybe really cheaper than doing laminates!:jawdrop: I love the feel of a wooden floor, used to have parquet at my old house. One question, to do parquet, you have to hack the floor?? Cannot overlay right?
Can send me the contact of the parquet contractor???
Pls also pm me the contact. Thanks.
  • 1 month later...
Can I have the contact for your teak supplier? Thanks
Attn: dht,
No matter whether you're laying laminate flooring / even parquet flooring, You must hack the existing floor tiles first as it depends on the age of the house.
Let's say your house is 5yrs & above, my suggestions would be hack first, clear the debris then do cement screeding. In order to cut down the "hollow sound", ask the parquet / laminate company to put the rubber foam under it as it will helps to reduce the hollow sound ups to 70%.
But to me personally, my preferences would be using SUPREME laminate flooring.
1. Parquet you have to resand & varnish over the time but laminate doesn't need to.
2. Parquet isn't scratch proof or scratch resistent but laminate is scratch resistent
3. Laminate is easier to maintain.
4. Laminate flooring now has engineer wood which is meant for commercial usage & also comes with termite resistent effect now. Terminate resistent laminate flooring will comes in only after cny
  • 1 month later...
hi writergal,
can pm mi ur contractor? thanks!
You can visit their website www.hauhauparquet.com.
When you call them, look for Susan she'll advise what's best for your home so bring your floor plan! The "layer" they recommended was Mr. Gan and his workmanship is great.
The guys who lay the wood will actually tell you which pattern is best to make your house look bigger so you might want to ask them for their opinion unless you have something specific in mind.
Cheers
Had anyone did a platform and top part is parquet? I'm not sure if the ID will just do the raising of the floor and then the installation of parquet done by another company. Anyone? :dribble:
  • 1 month later...
Hope you guys can help me.
Hauhau quoted me about $5.00 for 12mm x 2" x 12" burmese teak strips exclusive of installation. Is this considered reasonable?
Thanks in advance.
Edited by phaffia
