Is Quotation Ok For New Standard 5 Room - 115 Sq M?
What do you think of my quote?
Mine is a new standard HDB flat with living room and bed rooms flooring bare. Im thinking of hacking the a bedroom wall, to make a WIW.
A) Masonry Works
Laying 600mm x 600mm super polished homo tiles c/w skirting in living and dining (up to $3 tile)(based on abt 52 sq ft)
Laying of Kronotex laminated flooring cw skirting for all 3 bedrooms
Construct 50mm washer base, cabinet base, fridge base
Construct 2 shower kerbs at 2 bathrooms
Construct main entrance kerb
Alteration of existing date
B) Plumbing Works
Replacement of standard stainless steel pipes
Labour for installation of instant heaters
Labour for installation of bathroom accessories
Labour for installation of kitchen sink
Laying of concealed drainage pipe for kitchen sink (?)
Laying of concealed drainage pipe for washer (?)
C) Miscellanous / General Services
supply & install 10mm tempered glass shower screen at master toilet
Supply & install split unit aircon for all 3 bedrooms
Paint whole unit's walls & ceilings with ICI emulsion paint
Paint all pipes, doors, doorframes & gate with ICI gloss paint
Revarnish existing main door
Plastering whole unit's wall grooves
Laying of cardboard protection on affected area
Chemical wash for whole unit
General cleaning upon completion
Price : $14,588/=
Top Up for Kitchen Cabinet
Design & fabricate 20 ft kitchen cabinet in ABS trimmings laminated door, including designer handles, cutlery tray
Installation of 2 tier stainless steel dish rack
Labout for installation of cooker hood & hod
Supply & install 10 ft solid surface worktop (brand Cerata- good a not?)
Price $1,688
Top up 20 ft kitchen cabinet to 38 ft cabinet - Add $1,800
Top up from 10 ft to 18.5 worktop - Add $680
Carpentry
Design, Fabricate & Install divider in laminate finish in Foyer (size 4 ft, full ht) $960
Design, Fabricate & Install shoe cabinet in laminate finish in Foyer (size 4.2 ft, full ht) $990
Design, Fabricate & Install feature wall in laminate, mirror or glass finish **** area (size 7.8 ft by 6.8 ft) - $1,680
Design, Fabricate & Install low TV console in laminate finish in living area (7.8ft) - $1,200
Design, Fabricate & Install walk in wardrobe in polyester finish in master bed room - $1,710.
Supply materials & labour for a solid surface vanity worktop $400
Design, Fabricate & Intsall walk-in walkrobe in polyester finish (9 feet?) - $1,710
Supply and install full size mirror at vanity area. $220
Demolish & Masonry Work
Hack of wall in bedroom $190
Supply labour to patch up after hacking of wall $230
Ceiling & Gymsbaord Works
Supply & install false ceiling at Foyer $460
Supply & install false ceiling **** passage $350
Supply & install false ceiling at Dining area $660
Supply & install L shape L box Light holder **** $220
Supply & install false ceiling at Master bedroom passage way $240
Supply & install light pelmet at Master bedroom $150
Supply & install plasterboard false wall to form walk in wardrobe $630
Supply & install LBox above vanity top at master bathroom $70
Total S$29,137
Any comments? Is this quote reasonable, can be considered as a good deal?
1. I like to know what are these? I did not ask for these - are these standard essential stuff to have?
2. I need to ask ID to write down the area in sq ft for the ceilings and Lbox right?
3. Also need to ask for quote for electrical work?
4. Package include laying of kitchen tiles and store tiles, but I dont need that, so ID only deduct $1,200 for me. I felt that the package seems expensive. MOst of the items in the package can be given f.o.c except for the big ticket items like flooring, so makes me think the $14,588 for the package is not attractive either.
5. May I know is it neccessar to install a washing machine tap? Whats that?
6. How about to change all PVC cold water pipe (as per HDB provided to us now) to stainless steel pipe or copper piping? Is this neccessary/ essential?
Help me to see - thanks for all your help!
Edited by mint
This is the extra tap in the kitchen/service balcony (depend where U want to put your washing machine) for your washing machine...
one of the ID actually told me that they won't change all the pipes, they will just replace the exposed pipes so those concealed will still be PVC. actually just extend the inlet/outlet enough liao
as for the concealed drainage pipes, it will depend large where you are putting your sink
if it's right above the 'designated' area, then no need. but if you are going to put your sink far far away from the spot, then you got to conceal the pipe under the flr tiles liao. imagine the water pipe running across your kitchen floor :)
the kitchen cabinet also very expensive
some place offering $888 for the 20ft with the standard ABS blah blah stuff if you take up their reno package
