Placement Of Ceiling Fan
Where to put ceiling fan in living room and bed room?
Understand that there is "no wind" exactly underneath the fan, is this true?
Usually it's at the side/perimeter of the fan that has the most "wind"
Hence if place in hall will be either
- between tv and sofa
- behind sofa
place in room will be not directly above bed, at one side
:notti:
  • Replies 30
  • Views 9.7k
I dun thnk that the ctr no wind is that big a consideration when considering placement. The ctr no wind zone is not that big.
Ideally, it would be best that after putting all furniture in then consider where to place the fan. If not, it would look rather odd to see a living room with an off centre ceiling fan.
Personally, I dun like ceiling fan in bedroom cos at nite, the ceiling fan blow wind directly onto the bed all the time. At least table fan can adjust to blow diff direction if weather is not that hot.
====== wall
Fan
X + l shape sofa
Normally see people place fan in th center like above, is this what you meant?
All my 5 fans come with light... so for the bedroom it is at the center of the room....
For the kithcen ... I have 3 light points... so it is at the dinning area...
for my living...I have 5 light points... it is in between the computer and sofa ... btw... I have one light point in between the sofa and TV.... so the fan is not in the center...
wall
computer
sofa
TV
wall
Edited by HSH21
Hi
For ur bedroom fan, does it come with yellow or white lights? Urs the type with hanging lights or the circular white light bulb? I am keen to get ceiling fans for my bedrooms, but i not sure if the light will be bringt enuff. how is the brightness of the light if you use ur fan light as the main light for the room?
wall
computer
sofa
TV
wall
Hi
We can choose whether we want yellow or white during our purchase... but I asked for white light... U can change the light to the higher Watt if not bright enough... my rooms only lighted by the fan lights... so far no problem...
MBR -
My girl's room..
My son's room.. the fan is same as the one installed in the kitchen...
my hall...
MBR -
My girl's room..
my hall...
Looks like center of the room will make it look more neat
Is that an amasco fan? For fans with lights will you have two switch on the wall? one to control light and other for fan?
Thanks
Thanks
Only the living room and kitchen have 2 swithches.... all the bedrooms due to couldn't lay another line ...only one swithch...
Which one U are referring to as Amasco ?? I got different brand... must check...
Thanks!
kinda like dajavu when I see the pics ... cos our homes is same layout :bangwall:
Thanks!
Ha... Ha... U are cheated by the photos...our layout is not the same... photos didn't show the true...
Chose a 3 lights model for my hall, think it will be sufficient? have a l box in front with 4 downlights too
Well... the brightness of the light all depend on the Watt of the bulb... if U find it is not bright enough ... just need to change the bulb ...
I wanted to buy one kind whereby i was told it uses those circular light bulb. For room, i dun want to use those with hanging lights. the circular bulb i was told got 40 watts, but bcos the size is small, so its wont be as bright. i looked ard but so far i hv never seen a circular light bulb that size but is 40 watts. that size normally is 22watts...
Since the bedroom only has one switch, how to control the fan? u just turn on the switch and then control the lights / fan via remote?
My MBR is using this type of light... it is different from the normal... two circular light joined together ... must ask my HB how many watt is that...
Ya I use the remote control for the MBR fan/light ... and that's the only way for it...
But for the rest of the fan/light... even there are two switches... there are two strings to each fan/light... one string to control the on/off or how many light U want to on... another string to control the on/off and speed of the fan...
Edited by HSH21
  • 3 weeks later...
Hi hsh
just wondering pics are taken of current place with furniture or ?
thinking of changing the colour of my fan i bought.
Hall colour is mainly:
- white ceiling
- milky white wall
- beidge tiles
- dark wood furnitures
it's between silver and antique colour now
silver will bring some shine while antique/brown will kinda go with the theme.
what say you?
