lifestyle
Lifestyle Blessed House
Very satisfied with the commitment & workmanship of our electrician (Jeffrey from ....) so far :notti: . He is very details, neat & dedicated to his work. Does all the work by himself as he like to control over his workmanship.
Hi lifestyle, :notti:
Mind posting the Electrician Jeffrey contact and the package you got from him?
Currently my electrician is quoting 2.5K for the whole house rewiring, but will require additional 300 to move the MCB down to adult height due to the new HDB regulation (my house is 4S Resale).
Thanks and hope to hear from you soon. :dribble: !!
Hi Tim,
Have PM you comments & Jeffrey contact details. Should be very favorable.
Cheers
:notti:
Thanks and hope to hear from you soon. :rofl::bleah:
Thanks hencpu. Well to have this big living area :notti: must settle for older flat :notti: .
Using 17-40L for all wide angle shots.
woah! nice big hall...
nice photos as well, 5D is awesome camera.. must be using 24-105L :bleah:
Hi lifestyle, :)
Thanks and hope to hear from you soon. :):yamseng:
remember to update us on the package ...
More pics from yesterday.
Replacing new Air-cond ...
Air-cond insulator pipes...
Air-cond copper pipes..
Edited by lifestyle
Thanks hencpu. Well to have this big living area :notti: must settle for older flat ;) .
miss this lens, used to enjoy the wide angle when using film camera last time, but now on 20D not so good :)
i must say, ur electrician is really good & neat... :notti:
Thanks hencpu. My only complaint for the 17-40 is it's not fast enough at F4 and the newer faster wide angle lens (16-??mm) is a bit too expensive.
You can look out for the new 40D when it launch soon :notti:
Here are some more pics of neatness..
miss this lens, used to enjoy the wide angle when using film camera last time, but now on 20D not so good ;)
Edited by lifestyle
You can look out for the new 40D when it launch soon :unsure:
woaah! tat's super neat... :rofl:
anyway, yeah...the new 16-35L MkII is good also, but very pricey
the 17-55IS is supposed to be the best wide angle L lens if can use on all bodies.
but too bad they give is an EF-S mount & cheap plastic barrel.
Thanks. Yup, the electrician did a great job....better than what i expected.
Here are more pics of our electrician in action ..
Bedroom flooring...
Wow ur electrician indead veri neat and tidy. :yamseng:
Waiting for more pics, even the air con pipes also look nice. :sport-smiley-004:
Edited by lifestyle
Need urgently advice on the following:
Would like to find out what is the different between Die Cast Aluminium Vs Die Cast Chrome for the spot light material? :P
Which is better & why?
Thanks a lot.
Personally prefer Aluminium. Virtually rust proof. But best if they dun do any coating on the alum. Coz may fade. Chrome will fade. Especially if you stay near the sea. I dun think there is a cast chrome. Chrome is a coating usually applied to cast iron.
See if the above makes sense. :dribble:
die cast means they are formed from a die (a mould) and not cut to shape by machinery.
aluminium are softer. and dun have those shining looks. aluminium are dull in colour.
hmm... die cast chrome... i believe maybe is die cast steel or iron. and then chrome is applied to it.
it is stronger, but the chrome may came off or flak off later...
Thanks wtg54 for your comments. Yup it make sense.
See if the above makes sense. :ph34r:
Hey Eric,
You are right and thanks for your input. I also noticed that the chrome is a lot heavier (maybe due to the underlying steel/iron materials) compares to the die cast aluminium type.
Most people also said chrome will peel off or tanished and have black color in the long run when exposed to strong heat from halogen light.
Got also replied in the Renovation-Electrical Work forum ... here
:good:
Edited by lifestyle
