Help Me Check My Quote... Thanks To The Help !
Hi ... i got another quote from another ID firm, can u check for me what is being over charged ? I feel that its very high, esp when I did not hack my exisiting marble flooring and not really much carpentary jobs done .. pls advice me ... thanks ...
I also feel that they never give me freebies such as aircon, tv, sink, hob, etc etc ???? But he says that everything is negotiable, he says the the everything about be ard 27K not 32K as quoted which i feel is also quite steep for not really much work done... no new floor n no laminates for all my rooms
enci
HAULAGE SERVICES
to hack FLOOR TILES at kitchen -$400
to hack MBR n Common Bathroom FLOOR TILES -$200
to hack WALL TILES at kitchen - $480
to hack WALL TILES @ MBR n Common Bathroom -$400
to demolish exisiting internal hollow block wall btw kitchen to hall - $80
to hack concrete support at exsiting Kitchen - $120
to hack exsisting vanity @ MBR n Common toilet - $80
to dismantle exisiting sanitary wares at MBR n Common Bathroom - $80
to dismantle exisiting kitchen cabinets - $200
clear of debris - FOC
load n unload of materials - FOC
CONSTRUCTION WORKS
to MAKE GOOD with chemical cement plastering for wall and ceiling that are affected by demolition works btw Hall and Kitchen - $220
to polish existing broken marble floor - $900
to apply waterproofing membrane for kitchen n service balcony - $240
to supply n lay homogenous art floor tiles for kitchen n service Balcony - $1400
to construct 2" height fridge and wasking mahine cement base with matching floor tiles - $160
to construct 2" height cabinet cement base with matching floor tile $200
to supply & lay selected homogenous art partial wall tiles at Kitchen - $1600
~(Common Bathroom)
to apply waterproofing membrane for bathroom before laying tiles - $80
to supply & lay selected homogenous art tiles at bathroom - $400
to construct floor height difference as shower kerb - $100
to supply and lay selected homogeneous art wall tiles - $1700
~(MBR Bathroom)
to supply and lay selected homogeneous art wall tiles - $1800
PLUMBING WORKS
to supply n change stainless steel pipe for kitchen - $180
to supply n change stainless steel piple for both bathrooms -$400
to supply n install 2 hot points for showers -$250
labour to install 1 tank storage heater -$100
labour to install 2 shower head/mixer -FOC
labour to install 2 Basins $120
labour to install 2 mixers/taps for basins - FOC
labour to install 2 pedestal toilet bowls $300
labour to install 2 sets of toilet accesories - FOC
Labour to install Sink n mixer tap - $60
to supply n install 1 PVC sewage outlet pipes for kitchen -$80
to supply n install 1 PVC sewage outlet pipes for both bathrooms -$160
to supply n install outlet pipe for sink and washing machine - FOC
to supply n install outlet pipe for basin and shower for both bathrooms - FOC
PLASTERING WORKS
to supply and install false ceiling, cove light holder and Lbox **** n dining -$1500
to supply and install false ceiling, cove light holder and Lbox with 1 set of curtain pelmet at bedroom2 -$300
to dimantle exsiting cornices **** n dinning room - FOC
GLASS WORKS
to supply and install 1 custom made 10mm thick frameless tempered glass fitted shower screen panel and casement door with fittings and stainless steel handle at MBR - $640
to supply and install 2 custom made 10 mm thick tempered glass fitted panel at entrance of kitchen - $790
PAINTING WORKS
to supply and paint ceiling at wet area with sealant paint - $180
to supply and paint whole house wall and ceiling with emulsion paint (ICI or Nippon) -$1700
MISCELLANEOUS
to supply corrugated / plastic sheet for floor protection - $180
labour to lay corrugated plastic sheet FOC
to supply n do general cleaning for whole house $220
to provide application of permit from relevant authority - FOC
CARPENTARY WORKS
1 Buddha Altar boxup feature storage divider (L900/700 X D400 x HT850/1600mm) -$1200
1 Hung TV Cabinet (L 3600xD600xHt400mm) $1300
1 feature wall with mirror **** (L4200xD150x2400mm) - $2100
KITCHEN
top cabinet (L2400mm) -$960
bottom cabinet (L4800) -$1920
1 stainless steel rack - FOC
1 cutlery tray - FOC
to install cooker hob - $30
to install cooker hood - $30
Cresto solid surface solid top (L4800mm) - $1280
to open hole for top mount sink - FOC
1 set of sliding door for heavy duty rack $900
MBR
1 wardrobe (L2700 x D600 x ht2400mm) - $2160
1 TV Cabinet $480
TOTAL: $30,940
5% GST $1547.00
GRAND TOTAL: $32,487
i can supply with with a painter contractor, charging 1050 for 3 coats of paint (inc sealer layer) for 5rm :P
i thin 1700 for painting a bit too ex. average paint shop charge 1400 only. :P
That is true, you can get a quote from Nippon itself (just go to those Homefix shops). Some of them have a Nippon paint counter. There's a price guide for the different type of paint and the different charges.
4 room is around $1500 or less if you choose Odourless/Medifresh/Easy wash range, it can even be cheaper if you choose Vinyl silk/Softmatt/Vinilex. So if your contractor charges so much more. Let them know how much you can get, if they can't match your price, you might as well engage your own separate painters?
i can supply with with a painter contractor, charging 1050 for 3 coats of paint (inc sealer layer) for 5rm :bangwall:
i thin 1700 for painting a bit too ex. average paint shop charge 1400 only. :dunno:
How many colors to choose from? Able to choose from any paint (3-in-1, gloss??)
They using 3-1 medifresh from Nippon which is washable paint but more expensive, i checked it is the 2nd highest grade in Nippon paint series. 8|
if u opt for non-washable Nippon paint, only 850 for 3 coats (inc sealer layer) 8|
Think u can only choose 2-3 colours, i chose 2 different colours, he say it's ok. dun know what's the limit. :bleah: pm me if u wan
Edited by Relacker
