Aircon Quotes (From Aron)
Hi Aron,
Can you quote me below for new bto including misc items?
ME starmex system 4- 2×9k, 12k, 18k
Similarly for Daikin invertor? Also, which brand do you recommend?
Thanks!
I have just PMed to you.
Thank you,
Aron (aronputt@gmail.com)
https://www.facebook...355281117982556
  • Replies 2.1k
  • Views 663.3k
  • I was told my a saleman selling aircon that the default grey insulation is good enuff if your aircon trunking is expose as most of the HDB are. And not hidden as those in the condominium. Armaflex ar
  • ok, there are retailers who try to cut corners to save $$. eg. they offer you system 3 at (est) $3.4k, generally the air-con mfgr specs will specify wat type of material to use, eg. for insulation, pi
  • i got a quote from gain city. Mitsubishi invertor, compressor is 30k btu, then 3X 9k units for 3 rooms, and a 22k unit for the living area. Cost is $3.4k. is it cheap? TO be honest, im a noob when it
Hi
Need a quote for mitsubishi Heavy Single split (18000BTU) + bracket.
inclusive of all costs
Pls include in the quote the type of insulation, copper pipe, drainage pipe, wires, no. of installation trips and warranty coverage.
Thank you,
Hi there, can I have a quote for the following:
Mitsubishi Electric single split inverter air conditioner - 9000 btu
Armaflex class “O” 1/2 inch thick insulation,16mm drainage pipe
Thank you,
Please quote for MIT electric Starmex, MXY4A28VA with 2x 10VA, 1x 13VA and 1x 26VA. Thanks
Aron,
Could you pls advise the costing for both MEL starmex and MHI (system 3) all in price and warranty pls.
Key collection should be end of this year.
Thanks in advance.
Aron,
Thanks in advance.
Thank you,
Hi all renotalk members, we are running a special air-con promotion for MITSUBISHI STARMEX:- (Please email aron at aronputt@gmail.com for this promotion)
A) Special Renotalk Price: $3850 nett for Mitsubishi Inverter system 4 (new model, 18kbtu + 9kbtu X 3)
B) Special Renotalk Price: $2999 nett for Mitsubishi Inverter system 3 (new model, 9kbtu X 3)
B) Special Renotalk Price: $2899 nett for Panasonic Inverter system 3 (new model, 9kbtu X 3)
C) Special Renotalk Price for brands like daikin, toshiba, LG etc. Single Split, System 2/3/4 available for both inverter and non-inverter.
* Free & no obligation Site Survey
* Free 2 trips installation (1st trip to run piping, 2nd trip to put up air-cons [if needed])
* Free dismantle and disposal of old air-con
* Free upgrade to Armaflex class “O” 1/2 inch thick insulation,G22 copper pipe,keystone cable (made in singapore),16mm drainage pipe
* Special coordinating work between us and customer’s contractor
* Special appointed installation team
* Special supervising work by head of installer
Terms & Conditions
*All promotion items while stock last
*All prices include HDB standard installation
We have set up a facebook page (link below) specially for you and all Star Cool customer who will like to seek for after sales service, air-con advise and quotation. Please kindly dropby and give us a like if you are satisfy with our services.
This facebook page will also serve as a channel for you to contact us if you have any enquiry in regards to your aircon.
Thank you,
Aron
Hi may i know what is the price for daikin system 3? Does it include thise upgrade as above too?
Hi Vicky,
Thank you,
i'm intersted in mitsubishi starmex inverter system one (12k btu). include installation. private house. Pls pm or email me price. elgin.ee@gmail.com
Hi can you quote me for a Daikin or Panasonic Inverter System 4 (4 x 9k btu - we're using for 3 bedrooms and 1 dining/study room) We already are using a non-inverter old aircon system so will need to replace old pipes but can reuse the conduits.
Hi Aron, can you kindly quote for :
Hi Aron, can you quote for supply and install :
- Mitsubishi Electric 8530 BTU single split inverter
- Mitsubishi Electric 11,940BTU single split inverter
- Mitsubishi Electric 21,000BTU multi split inverter
We are staying on ground level. thank you.
Please Pm me about Mitsuibishi starmex inverter sys 3x9k btu or Hitachi inverter sys 3x9k btu.
HDB 3M rooms 82 sqm.
Please state the no of trips for installation, warranty period, any restrictions for piping, the type of copper pipe, drainage, insulation material and thickness.
Prefer armaflex class 0.5", .22 guage copper pipe, .16 drainage
Thanks cheers.
