Ea Electic Work Quotation
Hi All
Experts please comment on this quotaion. is it reasonable.
Kitchen & Service Balcony
a) re-casing and shifting of existing (power points & switches) points to $150.00
propose position
b) 1 no. power point for cooker hood $28.00
c) 1 no. power point for built-in oven $28.00
d) 1 no. 1 X 13A power point for fridge $42.00
Bathrooms
a) re-casing for both bathrooms $150.00
b) 1 no. lighting point for master bathroom vanity top $28.00
c) labour to install of 2 nos. of exhaust fans for both bathrooms $50.00
Master Bedroom
a) 11 nos. of lighting points $308.00
b) 1 no. of 2-ways switch $28.00
c) 1 no. of SCV $80.00
d) 1 no. of 2 X 13A power point $55.00
e) 1 no. CAT 6 LAN point $60.00
f) shift 1 no. lighting point for ceiling fan $20.00
g) labour to install ceiling fan $35.00
h) shift 1 no. 1 X 13A and TEL point $20.00
Bedroom 3 (Guest Room)
a) 2 nos. of lighting points for ceiling lights $56.00
b) 1 no. of lighting point for display beside window (with dimmer) $56.00
c) shift 1 no. of 1 X 13A power point $20.00
d) shift 1 no. of lighting switch $20.00
e) labour to install ceiling fan $35.00
Bedroom 2 (Kid's Room)
b) 2 nos. of lighting points for display beside window (with dimmer) $112.00
c) 2 nos. of lighting points for head-board (for reading) $56.00
d) 3 nos. of 1 X 13A power points $126.00
e) shift 1 no. of lighting switch $20.00
f) labour to install ceiling fan $35.00
g) 1 no. CAT 6 LAN point $60.00
h) 1 no. of 2 X 13A power point $55.00
I) 1 no. SCV $80.00
Prayer Room
a) 1 no. wall fan point $28.00
b) 1 no. of lighting point for ceiling light $28.00
c) 1 no. of 1 X 13A power point $42.00
d) labour to install 1 no. wall fan $25.00
Study Room
a) 1 no. CAT 6 LAN point $60.00
c) 1 no. of 2 X 13A power point $55.00
d) 1 no. lighting point for study $28.00
e) shift 1 no. lighting point for ceiling fan $20.00
g) shift switch $20.00
Living, Dining & Balcony
a) 18 nos. of lighting points $504.00
b) shift 2 nos. of lighting for ceiling fans $20.00
c) labour to install 2 nos. of ceiling fans $70.00
d) shift TEL & power-points for living, dining and balcony $20.00
Others
a) labour to install 53 nos. of light fittings $424.00
Total:- $3,505.32 including GST
Above electrical quotation is inclusive of labour, materials and
using big panel designer switches.
Thank you Chunky, But how about the price is it reasonable in sense of $$$$.
price is good too
A To supply and lay lighting / switch point (exposed) 8 nos $280.00
B To supply and lay lighting / switch point (wall concealed) 1 no $70.00
C To supply labour to relocate lighting point (concealed) 2 nos $100.00
D To supply labour to install light fitting 26 nos $260.00
E To supply labour to relocate 1 gang light switch (concealed) 2 nos $80.00
F To supply labour to install ceiling mounted fan 2 nos $90.00
G To supply and relocate 1 gang 13A switch socket outlet (concealed) 2 nos $90.00
H To supply and install 2 gang 13A switch socket outlet (exposed) 3 nos $165.00
I To supply and install heater switch for exhaust hood / cooking hob 2 nos $140.00
J To supply and install 15A switch socket c/w cover 1 no $90.00
K To supply and relocate telephone point (concealed) 1 no $50.00
L To supply and change all switch socket and covers to MK (silver color) Lump Sum $165.00
2 nos 2 gang light switch
3 nos heater switch
1 no 1 gang switch socket
5 nos 2 gang switch socket
Since we are on this topic, appreciate if someone can please comment on my quotation. It's for EA too. The last item on chaning the switch socket and cover is the same one I am discussing in the other thread.
http://www.renotalk.com/forum/index.php?sh...mp;#entry230864
Sorry I too will tag along on this topic.
Can somebody pls tell me if this quote is ok.
I know for installation of ceiling fan $70 is too much...
but he says he will give another $100 discount overall..
somemo saying need to hurry coz before tiling must decide,
Despite all planning got caught unprepared for electrical works :)
QTY COST
1. supply labour to install ceiling light #3 30
2. " " " fans #7 490
3. " ' to lay new points and install wall lights #6 210
4. To supply n install 13 A (double) points #6 300
5. " " " ' '''' " (single) points #2 90
6. TO supply n lay new 15A A/C isolator switch #1 120
7. To supply n lay new 15 A heater point #1 100
8. To supply cooker hood and hob switch #2 160
9. To supply n lay new SCV points #2 160
10. To supply labour to re-instate back the cables for 2 baths and kitchen 1 lot 230
TOTAL 1890
DISCOUNT 290
GRAND TOTAL 1600
Edited by Lakmy
Please refer to first post. I still need to buy fans and all the lights. I still think its a bit high or are there too many lights I think i should reduce the numbers of lights. Any comment?
--indee
--indee
sorry for being frank - u really got too much lighting points liao.
look at mbr - for me i got only 2 but you got 11 :dancingqueen:
dining i got only 1 pt, living room 3 pts.
Hi MaCe,
I do not mind you being frank and thanks for confirming that there are too many lights.
For MBR I have a F Celing so it has four lights and then two in the Walk in wardrobe and passage two dim lights on top of the TV. and one for the study table.
I got F ceiling for Living and dining too. But any way the message is its toooooooooo many and end up me paying the bills.
Is there any guide line I can refer too for putting lights. its a EA (131 sqm.)
thanks for your help and frankness really appreciate. I think this forum serve the purpose because of members like you.
Edited by indee
Hi MaCe,
:dancingqueen:
dont make me happy siah....wakkaka
when i said your price is good becos market rate ;
lighting pt = $30
installation of lights = $8
the rest are either $5 or $10 dollars difference...conclusion is your electrician is giving you the market rate. he is not chopping you.
number of lights really depends on your design.....(this is the main reason).
mine is a EM 146sqm but my lightings pts total around 22 or 23 nia...cos i also take the PUB bill into acct....now me paying liao not my parents. !!
Hi MaCe,
:dancingqueen:
My EA also 131sqm. Currently waiting for another Electrician's quote. The 1st electrician quote me 3k. I wasnt happy cos no rewiring done. I feel its not really worth it. I got abt 40-50 lighting points. Will update here when I get the quote with the Electrician I met today.
Hi RenoGirl,
great please post that so that we can share the knowledge. I also got the key ard that time I guess 8th Aug. My quotation is from the ID who is doing the reno work. He alrdy chop me in that :dancingqueen:
Hi... I have engaged Eric to do my electrical works. I have counted. Total I have abt 34 New lighting points. The rest are existing. and generally a lot of shifting here and there. New switch point, new socket points. He give me a lump cos we told him its ok to give us a lump as long as price is cheap!
Really like his service, he listens to ur needs and design attentively and offer alternative suggestions to hide the trunkings in places where he think can hide. :jawdrop:
Unlike the previous electrician, never listen to what my hubby says and everything ok ok! Then quote us 3k the next day with all the points wrong and such! And still got the cheek to ask for 50% downpayment.
My electrical works starts today and will the wirings and points will be done by monday. Payment scheme also very gd. 30% 30% 40%.
If you haben found 1 electrician, maybe you would like to try Eric as the others forummers always recommend! ;)
Edited by renoGirl
Really like his service, he listens to ur needs and design attentively and offer alternative suggestions to hide the trunkings in places where he think can hide. :bow:
If you haben found 1 electrician, maybe you would like to try Eric as the others forummers always recommend! :notti:
I also used Eric during my hse reno last year, no regret!
He is very forgetful but nice guy, his workers are good and most important, his price is best in town :)
Is Eric a freelancer or does he have a company? Because this guy freaked when I asked for his company name, thereby making me think that he is not running a legitimate business.
